I was wondering how you people prepare your videos prior to editing?
I have my Vegas project set as 1080p 25fps progressive but I am using all kinds of footage of all different resolutions & framerates & formats etc etc. I know upscaling lower-res footage comes at a price but that's ok for my purposes here.
I just wondered, should I let Vegas do all the re-conforming the imported footage to my project's specs? Or can I squeeze some more quality but using some other software for preparing my videos?
Yes I realise normally I would set the Project settings to match the imported video. But in this case I need the Project at a specified setting, using video assets of all different sizes & formats etc etc.
What is your process in situation like this thank you
People have different workflows and preferences . You can go from A to B in many different ways.
It really depends on your project goals and asset specifics
There are some situations where you definitely want to (and/or definitely have to) use other methods as a workaround, because of known issues. For example , some formats are not compatible with vegas (e.g. MKV container), or prone to sync issues (VFR) etc.. Probably dozens of other little things or "gotchas" .
But for the most part everything will be converted to your project timeline settings quite well
And yes, you can get slightly better results using other programs for things like upscaling, and deinterlacing.
And for certain scenarios, you might want to perform a different type of frame rate change (Vegas can do blends and frame repeats/drops but not optical flow type interpolation) -
resizing of progressive footage should be ok in Vegas,
but resizing of interlaced footage, like DVavi, that is going to be messed up, better to deinterlace it before loading into Vegas,
frame rate conversion is handled two ways, setting disable resample or to allow it for a clip,
disabling resample just copies or skips frames,
allowing it uses interpolate or blend for frames, that is set in project properties, so just basic algorithms, results might not be desirable
Video editing project
By murusharmi in forum EditingReplies: 1Last Post: 4th May 2016, 05:52 -
what can really vegas import from an adobe project ?
By rama in forum EditingReplies: 4Last Post: 4th Apr 2016, 01:40 -
How to fit/resize a 720x480 4:3 video into a 720x480 16:9 project?
By brassplyer in forum EditingReplies: 14Last Post: 2nd Feb 2015, 15:14 -
Import mp4/H.264 videos into Premiere Pro or other video editing tools
By Julyy in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2014, 09:16 -
capture screen size and video editing resize
By muffinman123 in forum Capturing and VCRReplies: 3Last Post: 29th May 2014, 16:19
