  1. I ticked off the GOP thing for chapters like VCDeasy says to and they still come out very weird in some movies. Eg. Right now i'm doing Vamp Hunter D bloodlust and different Encodes(diff CQ bitrate yada yada) do different things, sometimes the chapters don't work, other times they skip to near the end, or only goes ahead 5 minutes and so forth.
    using CQ at 68
    200max 300 min
    3 to 2 check box to make the movie 29 fps(it's 23.976)
  2. have you demuxed the mpeg and remuxed it with bbmpeg and scanoffsets first?
    tmpeg produces chinese standard mpeg.
    i know vcdimager does scanoffsets, but i personally found bbmpeg better.
    have you not tried writing your own vcdimager scripts? They are not hard really and you get more control.
  3. well the weird thing is it worked just peachy with Vampire Hunter D which was 29.796 FPS
    then a 23.796 or whatever that is movie I keep trying as 3:2 pulldown yada yada and a million different ways to make a 29 fps movie and the chapters just don't work right.
    and BBMPEG hates Win XP even with the patch :|
