Results 1 to 27 of 27
No, it's still resulting in a variable framerate. It doesn't seem to matter which video I choose either.
If I save as AVI then it doesn't have this issue, but it says enclosing H.264 within AVI is a bad idea. MKV is not compatible with some smart TV's, so that's not an option.
I tried a couple of samples I had laying around in my PC and it followed the rule I stated above.
Constant source produced a constant clip and
VFR source produce a VFR clip - on both occasions I'm using "copy" for video and consequently not re-encoding
My version of Avidemux 2.70
Have you looked in Mediainfo's report to see if there are any further clues? -
I am also using Avidemux 2.70.
General
Complete name : C:\Users\Hypersonic\Videos\before.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/mp41)
File size : 976 MiB
Duration : 13 min 30 s
Overall bit rate : 10.1 Mb/s
Encoded date : UTC 2017-12-15 22:10:41
Tagged date : UTC 2017-12-15 22:11:31
TIM : 00;00;00;00
TSC : 60000
TSZ : 1001
Video
Format : AVC
Format profile : High@L4.2
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 4 frames
Codec ID : avc1
Bit rate mode : Variable
Bit rate : 9 783 kb/s
Maximum bit rate : 10 000 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 (60000/1001) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.079
Stream size : 945 MiB (97%)
Language : English
Tagged date : UTC 2017-12-15 22:10:41
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format profile : LC
Codec ID : mp4a-40-2
Source duration : 13 min 30 s
Bit rate : 317 kb/s
Maximum bit rate : 414 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 30.6 MiB (3%)
Source stream size : 30.6 MiB (3%)
Language : English
Tagged date : UTC 2017-12-15 22:10:41General
Complete name : C:\Users\Hypersonic\Videos\after.mp4
Format : MPEG-4
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 194 MiB
Duration : 2 min 38 s
Overall bit rate : 10.3 Mb/s
Writing application : Lavf57.71.100
Video
Format : AVC
Codec ID : avc1
Bit rate : 10 000 kb/s
Frame rate mode : Variable
Minimum frame rate : 59.881 FPS
Maximum frame rate : 60.001 FPS
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.080
Stream size : 188 MiB (97%)
Audio
Format : AAC
Format profile : LC
Bit rate mode : Constant
Bit rate : 317 kb/s
Stream size : 6.00 MiB (3%)
Default : Yes
Alternate group : 1 -
You mentioned other "dedicated video splitting apps" ; which ones did you try ?
You can try lossless cut it should preserve CFR , but like avidemux the cut points will only be GOP accurate
https://www.videohelp.com/software/LosslessCut
https://github.com/mifi/lossless-cut
Alternatively, it's possible to "fix" using a second step by editing timecodes . eg. mp4fpsmod. Not as ideal, but it will work . -
I tried Boilsoft Video Splitter. It also didn't work for me.You mentioned other "dedicated video splitting apps" ; which ones did you try ?
Lossless Cut worked for me. Thanks.You can try lossless cut it should preserve CFR , but like avidemux the cut points will only be GOP accurate
https://github.com/mifi/lossless-cut -
Why does Lossless Cut create files that freeze for a second at the beginning of every clip?
I think it's because it's using an edit list. There is an edts atom , and some players might handle that differently .
You can ask the developer or post a bug report or enhancement request
https://github.com/mifi/lossless-cut/issues
Or you can cut with another method and use the timecode fix method to force cfr -
It's because MP4 uses a time base of 1/90000 seconds. Frame rates like 23.976 can't be represented precisely as N/90000 so the muxer alternates between 3753/90000 and 3754/90000 to give an average of 90000/23.976 (~3753.75). PAL frame rates, 25 fps and 50 fps, can be represented exactly as 3600/90000 and 1800/90000 respectively.
More sensible containers use a time base that's represented with an explicit numerator and denominator. So a frame rate like 24000/1001 can be represented exactly.Last edited by jagabo; 24th Oct 2018 at 22:32.
MP4 supports other timebases. eg. You can use a 1001/24000 timebase, which results in CFR for a "23.976" video . That's one of the ways in which you can fix it - setting the time base
It's certain muxers, certain programs (e.g. handbrake) that use a default timebase of 1/90000 that cause the problem -
mp4fpsmod doesn't work. I don't know what parameters to use for it. It seems like everything I try results in an unplayable file.Or you can cut with another method and use the timecode fix method to force cfr
What do you mean it doesn't work ?
You just set the fps . Since it's every frame affected you precede it with 0.
e.g for "23.976" (or really 24000/1001)
If it was "59.94" as in your example above, you would use --fps 0:60000/1001Code:mp4fpsmod "INPUT.mp4" --fps 0:24000/1001 -o "OUTPUT.mp4"
You can do in-place editing (edit the file, without writing another file) by using --inplace . But I wouldn't do that until you're more confortable with it -
It just plays a gray screen in VLC with the audio skipping or no audio at all. It does this with any VFR mp4 file.What do you mean it doesn't work ?
e.g for "23.976" (or really 24000/1001)Last edited by Hypersonic1; 26th Oct 2018 at 15:18.
Maybe you didn't cut it correctly ?
It works here to fix, and in sync, in VLC for all AVC CFR files (that were cut properly on IDR keyframes, and as a result of muxing results in VFR)
There are other ways to fix it too - you can change the timebase/timescale directly with lsmash timelineeditor . But that only works on VFR files that were the result of incorrect timebase/timescale during muxing . But there are other causes of VFR from cut CFR . mp4fpsmod should work on all of them, it's the most robust method -
Actually, maybe it had to do with the fact that I exported them as MP4v2. I tried exporting as MP4 and it worked.
Did you check your cut mp4v2 file, before using mp4fpsmod ? did it play ok before using mp4fpsmpd ?
What version of mp4fpsmod were you using ?
In theory, mp4v2 shouldn't make a difference, because mp4v2 support was added to mp4fpsmod 0.25 -
I am using mp4fpsmod 0.25. I am sure that I cut it correctly. I have tried several different mp4v2 files and they don't work correctly after using mp4fpsmod. If I convert them to mp4v1 then mp4fpsmod works properly. I will just use mp4v1 since I don't actually need mp4v2.
I can replicate the issue with mp4v2 cut with avidemux - but it works with mp4fpsmod 0.24, or lsmash timelineeditor
So looks like something up with 0.25 . Can you just do a quick check with 0.24 to see if it's ok on your end ? -
Remuxing variable framerate video?
By TBMNY in forum Video ConversionReplies: 5Last Post: 20th Jun 2018, 17:34 -
Variable Framerate to Constant Frame Rate
By jjcinema1 in forum Video ConversionReplies: 5Last Post: 6th Nov 2016, 20:29 -
Variable FrameRate
By Lazare Londaridze in forum Newbie / General discussionsReplies: 111Last Post: 11th Sep 2016, 02:00 -
Need help working with video with variable framerate
By nfshp253 in forum EditingReplies: 8Last Post: 31st Jan 2016, 02:59 -
Variable or Constant Framerate?
By JackDanielZ in forum Video ConversionReplies: 56Last Post: 4th Aug 2015, 07:14
