I currently own a Mac Book Pro, my wife loves to make videos but wants to be able to make full length home movies and vacation movies and put them on a USB that we can then plug into any TV and watch. Unfortunately when we try we get error messages and Apple Gienus bar told us we have to keep them under 5 minutes because “no one makes full movies anymore”
Can anyone help me out here. I want to get Vegas Pro or Final Cut Pro X but don’t want to waste my money for 3 minute clips of my vacation.
Hi,
read about apple genius bar and wouldn't never ask them.
Post mediainfo of your file, error messages you got and probably someone will helps you. Problem is what format of video TV support, what camera format or cell phone is recording. Mediainfo will tell you exactly details about your videofile, and manual to your TV should tell you what Format (containers and codecs) are supported.
Genius bar are never wrong, even if your computer is on fire, it is not hot, is warm
have to laugh.
Bernix -
Lol, ok I’ll try and put another movie on my USB but I’m fairly sure it told me the file was to large, which I now see is because it’s Fat32. I’m really trying to not have to use a DVD but it seems like I might have to go back to them.
If Tv supports MKV you can easy split big files into 2 or several smaller files. Mkvtoolnix for example. But it depends on your TV and also codec. Supposing DVD - Mpeg2?
Your TV may well recognise USB drives formatted in either NTFS or exFAT etc. Neither of these have the limitations on file size that Fat32 does. I'd try formatting a USB stick as NTFS and try your video file on that. I see you're using a Mac so I think I'm right in thinking that although NTFS isn't the preferred format for Macs, it should be supported by the Mac?
As Bernix has already said, you basically need to find out what file systems your TV will accept on a USB memory stick and what spec of video files it will play from said USB stick. (Also if there are any special considerations like max bitrate, audio codecs etc.)
Let us know how you get on. Good luck!Last edited by TimA-C; 2nd Oct 2018 at 14:23. Reason: Possible early onset senility . . . or just being a forgetful old fart?
MagicDrop, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic. Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
And welcome to our forums.
Just “any TV” is going to be a problem, because all TVs are different, and the playback from USB isn’t standardized in any formal way.
If you are lucky, then MP4 is supported, with H.264 video and AAC audio. If you are lucky, up to HD (1920×1080) resolution.
If you are lucky, then FAT32 file system is supported. Nah, actually the most likely. FAT32 limits the file size to 2 or 4 GB max, depending on formatting options. The TV may have lower limits. I don’t think you will hit the file size limit, but if you do, then you could e.g. split it in two, part A and part B.Last edited by Case; 3rd Oct 2018 at 14:36.
Ultimately, the answer to these types of questions is always, get a standalone media player for ~$50 that will highly likely play your videos just as they are.
As stated above, your TV's built-in player is very limited in what type of videos it supports. You'll be spending precious time configuring your video to meet it's limitations as well as reducing the quality by reencoding. Even worse is converting it to play on your DVD player which is limited to 480p SD quality.Last edited by lingyi; 4th Oct 2018 at 11:59. Reason: Correct 720p to 480p for DVD
Old usb memry stick change created fails
By Budman1 in forum ProgrammingReplies: 4Last Post: 10th Jun 2017, 11:54 -
mp4 files not playing from a usb stick
By jacob2014 in forum Newbie / General discussionsReplies: 7Last Post: 16th Feb 2016, 17:03 -
VOB file displays "1 sec" length, is actually 29mins, plays full length but
By neonnebula in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2015, 20:12 -
moving files from android to usb mem stick or pc
By vhelp in forum Portable VideoReplies: 15Last Post: 28th Dec 2014, 16:30 -
MP4 out of sync on USB stick when FF
By tom z in forum Newbie / General discussionsReplies: 5Last Post: 28th Jan 2014, 00:15
