Hi. Wasn't sure where to put this.
So a while back I ordered these imported British DVDs, without knowing about region formatting and such, and thus they didn't work in any of my American dvd players. That was, until I found this old, cheap, player (Electrohome) that somehow would work. Until recently, however, when connected to my TV, after minutes of watching the audio would starts forming into a loud buzz and the original audio would go quiet. Now, there isn't even a buzz, though that could be because I fiddled with the cords (standard yellow white red) a bit, but the video still works. So I go and try to play it on my laptop, which works, but without the audio. Checking the dvd's files, I find that there are no audio files. Which is strange, because further back I thought the audio file had been filled. It all worked at one point. What's going on here? Thanks for any help.
Similar problem: https://www.ecoustics.com/electronics/forum/home-video/429875.html
If the player worked before then the player is at fault. But do try a different composite red/white/yellow cable as well. Audio is not a NTSC/PAL issue.
BTW you do not see any audio files on a dvd. The Audio_ts folder is empty. Actually redundant for a normal dvd-video disk. All audio is included in the vob files in the video_ts folder.
Using a British (UK) Panasonic DMR-E500H in North America (US)
By jwillis84 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 30th Oct 2018, 19:48 -
PBS download troubles again
By xtal_01 in forum Video Streaming DownloadingReplies: 4Last Post: 26th Oct 2014, 18:12 -
Unknown British Video Games TV Show 90s…
By retroborg in forum Off topicReplies: 0Last Post: 25th May 2014, 07:11 -
Troubles with MeGui -crash-
By anchonio in forum Video ConversionReplies: 7Last Post: 7th Dec 2013, 07:12
