Results 1 to 12 of 12
    Jul 2001
    Maryland
    i want to run an ftp server so i can retrie files off my computer during school and send files from school to my computer
    How do I do this?
    (My laptop is always on, running cable net)
  2. If you have a static IP, then just get Serv-U, it's great software I use it myself, haven't had a single failture with it.
    If you have a dynamic IP, the ontop of Serv-U, also get DNS2Go or any other program that does IP to name translation.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. I have G6 FTP which is also the same as Bullitproof FTP v2.15 and basically you just set it up.
    If you are used to settings in applications then it is pretty much straight forward.
    It took me about 1/2 hour first time I looked at it so it can't be that hard...
    (This is me we are talking about.... )
    Just be carefull setting your directories up incase you want to give out your login details anytime...
    Dont wanna give people access to your complete H/Drive now do you....
    Jul 2001
    Maryland
    Serv-U runs as a service and I don't want that, the server needs to be on only when I"m at school.
    WS_FTP server, I can't log into it using a client, says it's not on, btu the servicve says it's running
  5. Free Flying Soul liquid217's Avatar
    Feb 2002
    Greg12, try the G6 server
    http://www.bpftpserver.com/download.html
    ive been running it for 2 years and it seems stable with plenty of features. You can set it as a service or you can just simply run it when you need it.
  6. Greg12, just wanted to let you know i've been running Serv-U for about 4 years now, and you can select if you want to run it as a service or load it when ever you want.
    Best Regards,
    Sefy Levy,
  7. Easy soloution is get them all and try them all...See which one works best for you...
  8. I Agree 100% with that one!
    Best Regards,
    Sefy Levy,
    Jul 2001
    Maryland
    I like Bulletproof
    How much security does it have?
    I like how I can set it to automatically come online at 7am and go offline at 4:30
  10. Free Flying Soul liquid217's Avatar
    Feb 2002
    as far as security for bulletproof (g6), i have not found any security holes or threats yet. It seems secure enough. I have had some issues where some of my friends couldn't log on, but that may have been their system. It also has a feature that a person can be banned if they hammer the server, a very nice feature for those who love to do that.
    Jul 2001
    Maryland
    no one will hammer, annoymus access isn't allowed.
    i did find it odd that it couldn't use port 21
    i set it to port 29
  12. Free Flying Soul liquid217's Avatar
    Feb 2002
    some dsl and cable isp's actually block people from running servers on port 21. that is probably what is happening
