  1. Member hydra3333's Avatar
    Oct 2009
    Australia
    Friends came back from an overseas holidays and have a hand-held camera video in which two self-centered pig-ignorant so-and-so's sitting behind them wouldn't shut up nor quiet down (even when promoted twice) during a night time performance involving relaxing music and a synchronized water/light show.
    Sometimes ... just sometimes ... do gun laws in the US feel right ? (for the politically-correct handicapped - no, not seriously)
    So, I was asked if it was possible to remove those idiot's voices from the audio.
    I didn't think so, however your suggestions would be greatly appreciated.
    Aug 2010
    San Francisco, California
    Maybe, if it's a stereo recording, the music has a wide soundstage and the voices are in the center.
  3. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    You could try Audacity or Adobe Audition both have a plugin 'Vocal Remover' based on the idea in most commercial stereo recordings vocals are placed in the centre of the sound stage. So if you recording is stereo you might be able to remove most of the offending narrative.... For me I would just dump the original audio and replace with suitable Muzak nondescript airline music and maybe a bit of internal passenger plane noise - easy enough to find
  4. Member hydra3333's Avatar
    Oct 2009
    Australia
    OK, Thank You. I suspect a hand-held camera has one microphone, but it's worth looking into anyway.
    In the end, if the music can be identified, then they could spend some time editing and syncing replacement audio if the footage is valuable enough to them.
  5. I know it's expensive, but a 7 day trial is available, so I think it will do. It looks very promising:
    https://audionamix.com/products/instant-dialogue-cleaner/
