The most recent thread I could find on this was from 2014, and there was a workaround for back then, but it no longer applies to the current version.
I just want the simple ability to play a single file without PotPlayer creating an entire playlist based on the folder.
If I click on only one file, I'd like to play only that file.
Thanks,
--Kizz
Preferences > General > When files opened: "Add only selected files to playlist".
PotPlayer: disable autoplay next in playlist
By madbucky in forum Software PlayingReplies: 3Last Post: 11th Mar 2023, 23:28 -
PotPlayer playlist confusion
By TBacker in forum Software PlayingReplies: 0Last Post: 15th Jul 2018, 23:04 -
Potplayer playlist bug/problem
By AsadAlrafidain in forum Newbie / General discussionsReplies: 0Last Post: 6th Jul 2018, 04:51 -
PotPlayer: Advancing the Playlist issue
By lemings in forum Software PlayingReplies: 1Last Post: 22nd Jun 2017, 13:40 -
potplayer add the playlist shortcut ?
By albatros44 in forum Software PlayingReplies: 0Last Post: 11th Aug 2015, 13:13
