I'd like to remove effect of smudge video successfully. I'm not sure if it's called "blue effect". Details are presented on screenshot. Actually I'm keen to use VirtualDub, XmediaRecode.
I appreciate all responses.
You may be able to sharpen the image a little but it is impossible to actually remove the blur as it is part of the video image.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
It's not a blur effect, it's just that whoever took the shot/video of a monitor did not focus the camera properly, not much can be gained by filtering.
There is chance that your camera analyse video with framerate different than source framerate (so 30 fps vs. for example 50 fps as source is interlace 25 thus TV perform deinterlacing and doubling framerate). There is possibility to recover proper framerate and perhaps apply some temporal deconvolution but i do not expect spectacular effects - it looks like this Polish public TV channel (TVP Info) - you should try to record directly stream on your receiver or perhaps just download this feed from web stream.
Also holding camera in hands do not help to record stable video - you should try to record in steady way.
How to remove or blur watermark in video using MeGuI
By king92898 in forum EditingReplies: 0Last Post: 17th May 2017, 02:48 -
How Do I Remove This? Some Sort Of Blocky Effect - Unknown Term
By MetalPen in forum RestorationReplies: 31Last Post: 10th Dec 2014, 19:08 -
ASS subtitles Blur effect in hardsubbing (XviD4PSP)
By PlayingTarot in forum SubtitleReplies: 1Last Post: 28th Nov 2014, 07:20 -
How do I remove blur from my MP4 file?
By JaneHarris in forum Newbie / General discussionsReplies: 7Last Post: 18th Dec 2013, 12:06
