Hi.
I'm an idiot with 0 tech knowledge.
I'm having trouble, for some time now, to encode subtitles using Avidemux, a highly well recommended program for the job.
My issue is, when I open a video on Avidemux, everything is fine and the audio works. When I input the subtitles and click on the preview, the subtitles show up, but the audio is gone.
I've tried, nonetheless, to encode the video like that, and it just ended up a audioless subbed video.
Have pity oh tech gods. Please help.
Do you actually need hard coded subs?
To get my video and subtitles into a single file, I simply drop a video file and sub file into MKVToolNix and the output is a mkv file.
I've not used Avidemux (which appears to be a conversion tool...thus you are changing the file type and likely the quality), but there are several guides on the bottom of the tool page here: https://www.videohelp.com/software/AviDemuxGoogle is your Friend
MTS with subs to FORMAT ? to play on DVD with subs
By ausrob in forum Video ConversionReplies: 14Last Post: 24th Mar 2017, 18:28 -
Using AVIAddXSubs to add subs to divx for PS3, subs cutting out
By ProfN in forum SubtitleReplies: 1Last Post: 23rd Dec 2016, 08:54 -
DVD(Video_ts) with subs to a file with hardcoded subs?
By hech54 in forum SubtitleReplies: 3Last Post: 30th Aug 2016, 14:45 -
Adding original subs to extended scenes where translated subs missing
By SidDan in forum SubtitleReplies: 2Last Post: 6th Aug 2015, 03:57 -
Error deinterlacing to encode videos in Avidemux?
By dandorf in forum Video ConversionReplies: 2Last Post: 26th Apr 2015, 10:44
