Aja KONA HDMI (price ~$900)
The crown's jewel:
- - Capture up to 4 1080p HDMI streams
- - Capture 1 4k/60fps stream
- - Supports 4:2:2 and 4:4:4 chroma subsampling
- - HDMI 2.0
Magwell Pro Capture HDMI 4K Plus (Price ~$900)
Another option
* I don't know about chroma subsampling
- - Capture 1 4k/60hz stream
- - Support HDR10 & 8-channel audio
- - HDMI 2.0
I have read mixed reviews about this product. Some state that the capturer chip is the same as the 4k/60Hz ElGato, which less than the half. Or that aren't able to capture uncompressed lossless.
AVerMedia GC573 Live Gamer 4K (price ~$290)
More compact solution
- - Records at 4K/60 1440/144 1080/240
- - Some people claim it has a 100ms audio delay
- - HDMI 2.0
This are my investigations so far. I could have missed plenty of devices, I don't have any direct experience with this products hence this post. I am thinking in buy one of those, but not certainly sure if it's worth to jump from the $300 price range to the Aja KONA.
I am really worried about chroma subsampling, I don't want to find an stream playing at unsupported rates by my capturer card, but I wouldn't really need 4 simultaneous 1080p streams. Which is what the Aja KONA HDMI allows.
Also I would want to record uncompressed lossless, at least that the video card support the I/O speeds.
Will appreciate any feedback![]()
Results 1 to 1 of 1
Lost VirtualDub capture preview after spring 2018 win 10 update
By mtamimi in forum Capturing and VCRReplies: 25Last Post: 23rd Nov 2018, 06:35 -
Should I capture a 1983 LaserDisc at 60fps ? (Concert footage)
By cjdavis83 in forum Capturing and VCRReplies: 1Last Post: 24th Dec 2017, 08:40 -
MPEG2 capture software for 720p@60fps?
By texas1 in forum Capturing and VCRReplies: 70Last Post: 27th Oct 2017, 00:00 -
Capture gameplay at 60fps even if the game only runs at 30?
By ConanEdogawa in forum Capturing and VCRReplies: 13Last Post: 8th May 2014, 17:10
