Here is the media info of the available file:
General
Complete name :Inna.Party.Never.Ends-In.Your.Eyes.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 2005.03 (qt )
File size : 4.35 GiB
Duration : 3 min 16 s
Overall bit rate : 190 Mb/s
Encoded date : UTC 2013-10-15 18:29:23
Tagged date : UTC 2013-10-15 18:30:21
Writing library : Apple QuickTime
Video
Format : ProRes
Format version : Version 0
Format profile : 422 HQ
Codec ID : apch
Bit rate mode : Variable
Bit rate : 188 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:2
Scan type : Progressive
Bits/(Pixel*Frame) : 3.633
Stream size : 4.32 GiB (99%)
Language : English
Encoded date : UTC 2013-10-15 18:24:50
Matrix coefficients : BT.709
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : sowt
Bit rate mode : Constant
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 36.1 MiB (1%)
Language : English
Since i have 100 percent of my collection which consists of bluray songs ripped in passthru M2TS mode(using DVD-FAB 10) from physical blu-rays , i want to convert this .mov file listed above to m2ts mode too without compressing its high(n beautiful!!) audio n video bitrate. Can some expert guide me in "noob mode "spoon-feed steps how to achieve this ? Or is there a converter already available which is capable of such conversion ?
Results 1 to 11 of 11
The MPEG-2 TransportStream container will not support Apple ProRes video streams. You will need to convert it to a supported video format, and all supported video formats are lossy. You will lose quality. You can only hope that you lose so little, you may not notice any loss. To be Blu-ray compatible, this will have to be MPEG-4 AVC (H.264) video with some constraints (I would suggest x264 interlaced with VBV-restricted CRF 12), I guess the audio you may keep as LPCM (but I am not sure, need to read the specs). No spoon feeding right now, sorry...
Thinking about it again ... "Lossless AVC" (x264: --qp 0) might be supported too. But that will not be Blu-ray compatible.
MPEG, h.264 and VC-1 are valid for BluRay, along with LPCM and Dolby AC3 audio. The basic requirements list is at https://www.videohelp.com/hd#tech while GOP sizes, bitrates, and other encoding requirements and restrictions are at https://forum.doom9.org/showthread.php?t=154533. Or you can always read thru the official BD specs if you can stay awake that long.
- My sister Ann's brother -
Dear guys thanks for ur valuable feedbacks, BUTttttt my requirement is NOT necessarily BD compatibility. It just has to be M2TS with near lossless(sort of crf=0) or if possible lossless in ONLY n ONLY M2ts container. i won't be making a bluray of it. it wud be played using Jriver Media Center only as a file
M2TS has requirements and restrictions, too. Why does it have to be M2TS?
@LMotlow, since the rest of my collection of bluray songs ripped from Bds in m2ts passthru mode are in m2ts only, i want to convert these very few proff resolution .mov files(which i got from net) into m2ts files with quality same as the original .mov files. Otherwise even these .mov files can be played flawlessly in Jriver MC. but i desire to convert them in near losslesss manner to m2ts.
Why convert them at all? If they can play in jriver already...
If you use lossless you will just increase the file size - it will become larger than the orginal mov.
If you use near lossless , low crf, you will still increase the filesize (albeit, slightly less than lossless) and reduce the quality by some amount .
I guess it depends on your eyes or your threshold for "quality loss" . How much quality loss is acceptable ? -
@ poisondeathray , if the container cud be just changed in copy mode, i wud be happiest. but since it might not be possible, i am striving for best posssible quality (size does not matter although as we go nearer to crf=0 size increases exponentially compared to original size ). Is there a way out to just copy the video in m2ts container n retain the PCM audio as well? if not plz explain the best posssible way to convert these to m2ts.
Nope .
It was already mentioned above - prores is not supported in m2ts (or any type of transport stream)
Also transport stream adds about ~6-7% overhead on average. (IF it was supported, you just COPY a stream from MOV or MP4 or MKV or any container into a transport stream and you would expect it to grow that much larger)
Lossless will increase the filesize, but not "exponentially" ; the reason is prores is minimally compressed to begin with. And you can use temporal lossless compression (prores is I=frame only) . Typically you might see 1.5-3x larger filesizes only (the factor is smaller, then if you started with something more lossy compressed)
Best possible option is to leave it. It's already highly compatible in programs like editors, compositing applications. Most software players should play it too. There is no logical reason to do otherwise. It's all "negatives" in your scenario . You're just increasing the filesize and wasting time for nothing
The next most common 10bit422 option , that supports lossless in transport stream , would be AVC (e.g. x264 in 10bit422 mode) , and HEVC is becoming more common too. Interestingly, AVC lossless compression ratio tends to be slightly higher than HEVC in lossless compression mode on most types of material
What’s in a Professional Video Workflow to Convert Analog Videotapes?
By lingyi in forum Capturing and VCRReplies: 3Last Post: 26th Feb 2018, 01:31 -
Decimate/De-duplicate H.264 video losslessly?
By tubagod in forum Video ConversionReplies: 11Last Post: 18th Nov 2017, 14:57 -
Cut/Copy .mp4 video losslessly to .ts container
By Rajesh Singh in forum EditingReplies: 2Last Post: 30th Aug 2017, 14:18 -
convert .bin to .m2ts
By erzane in forum Blu-ray RippingReplies: 0Last Post: 25th Jul 2015, 10:36 -
How do i convert a large (33GB) video file (.mov) to mpg?
By cocobeware in forum Video ConversionReplies: 8Last Post: 24th Dec 2014, 08:57
