Hi.
When I compress any video with Handbrake, In the result video, when I want to move video forward with mouse it doesn't start exactly from the place where I clicked there! It's weird! I don't have this problem with other standard videos. Do you know what's the reason of this problem ? And how can I solve this ?
Results 1 to 20 of 20
Your player is set to "Fast Seek". When you random seek to a point in the video it automatically starts at the nearest key frame. Turn off Fast Seek if you want to seek to exactly where you specify. But it may take several seconds with very long GOPs. Use smaller GOPs if you want more accurate Fast Seeks, or faster accurate seeks. Smaller GOPs will lead to less efficient compression.
Hi,
problem can be, that you have set large GOP in Handbrake using demanding codec like H265 and not such powerful PC. If you use same software for playback, there can be different settings in search for different codeck. You click somewhere, program has to go back to key frame (frame that is fully described) and then from this point go, where you exactly pointed your mouse. So xvid is really not demanding and even on slower computer it is realtime. But H.265 with large GOP can take time. So some software players solved it to using search and play from first keyframe which is closer to start of video (from point where you clicked)
So there are several possibilities.
Edit: Too slow writing response and solving internet issues by phone
BernixLast edited by Bernix; 24th Sep 2018 at 11:27. Reason: Edit
What encoder are you using? With x264 or x265 you can enter e.g "keyint=50" (without quotes) into the "Extra Options" field you find in the "Video" tab.
But I agree with what jagabo said earlier: seeking should be accurate irregardless of keyframe interval. Maybe your player is not set up correctly or bad. Also make sure you are on the latest HandBrake version (you can test the latest nightly version as well) -
deleted
Sneaker wrote it already
In potplayer for example is default in Preference/playback time skip checked jump to keyframe. Unchecking it is desired behavior but there is small chance you are using potplayer.Last edited by Bernix; 24th Sep 2018 at 11:39. Reason: edit duplicity
This is why is 250 by default. 50 frames so at 25fps every 2 second the frame has to be fully described. it means 5x often. Also check search method in kmplayer.
Btw, is it part of presets, that GOP can't be configured when preset is selected, or is it just feature of Avidemux. Unable to change anything using presets? I thought there is no reason to not be able change GOP using CRF + preset.
EDIT:It was another solution way. I really appreciate you but actually in general I couldn't tell all of my customers to set this setting!
BernixLast edited by Bernix; 24th Sep 2018 at 12:03. Reason: Edit
Just last thing. Keyframes are usually placed where is big difference in picture. Scene cut. Codecs benefits most from similarity of sequence and similarity of pictures. So you can set how agresively they are inserted. To make GOP very low is probably good for watching security or other cameras footage. Here I see reason for precise search. On other hand here can codecs benefit very much.
I'm try to say, that in most cases are Keyframe inserted when there is cut in video. So most common is in fast search it starts with begining of scene. There is not much scenes very long in ordinary movie. Also you now have GOP fixed to 50 frames. Independently on content. Min and Max is now same. Min is default also 50fps.
Also you presume all your customers have computers of same specification.
Some experts on Bluray can tell you what is standart size of min max GOP in Bluray specification. I believe it is 50 and 250 or similar. So I wouldn't care about customers, when you are close to standart. Other can complain about size or quality when you do not utilize all feature of codec. There are users using gop with lenght 500.
Bluray mentioned because it use H.264 with AAC and Full HD. If users are satisfied with this standart and they are i believe, no reason to change GOP max. You are loosing quality or increase file size.
Btw when you unchecked keyframe search and helped it on video with long GOP? If yes i believe anybody can do same if needed search preciselly. Also if they needed specific frame, there is in most players 1frame forward backward movement.
Bernix -
Blu-ray GOP size is limited to 1 second. So 24 frames at 24 fps, 60 frames at 60 fps, etc.
Problem with conversion in Handbrake in the background.
By AJX in forum Video ConversionReplies: 1Last Post: 16th Dec 2017, 01:24 -
Framerate problem with Handbrake??
By bagmand in forum Video ConversionReplies: 1Last Post: 6th May 2015, 10:33 -
Problem with Handbrake
By synnchan in forum Newbie / General discussionsReplies: 3Last Post: 1st Jul 2014, 15:42 -
By Cygnus111 in forum DVD RippingReplies: 6Last Post: 30th Jun 2014, 13:26 -
Handbrake problem, please help.
By PonyoBellanote in forum Video ConversionReplies: 9Last Post: 8th Dec 2013, 13:59
