Video from my DV camera is being captured interlaced. I once saw instructions on this site somewhere that showed me how to use the Smart Deinterlace filter in Virtual Dub to fix the problem and it worked wonderfully, converting interlaced images in to crystal clear frames. I'm trying to do the same thing using the Deinterlace option under Field Options in Adobe Premier 6.0, but the results are nothing like what I experienced in Virtual Dub. It seems to soften the lines caused by interlacing, but it doesn't get rid of that shadow that is created by fast movement.
Anyone with Premier 6.0 experience that can help me?
Results 1 to 1 of 1
Sony Vegas de-interlacing issue
By Vman94 in forum EditingReplies: 16Last Post: 2nd Dec 2010, 00:17 -
interlacing issue
By mathmax in forum RestorationReplies: 2Last Post: 2nd Jul 2010, 07:28 -
Adobe Premier Elements 4
By Jedi5 in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2008, 22:01 -
Adobe Premier Elements 4 audio issue
By Dark Alpha in forum EditingReplies: 0Last Post: 26th Jan 2008, 16:02 -
problem with my adobe premier 7.0
By pondleaping in forum EditingReplies: 4Last Post: 13th May 2007, 10:29
