I'm trying to compare two clips using the following:
The script works when using x86 AvsPmod, AviSynth, and VirtualDub.Code:# If Videos start at different frames use frameadjust to align them frameadjust=0 name1="Source - Parallax.d2v" name2="Vegas Output - Parallax.avi" # Videos to compare: (v1 is original, v2 is encoded or whatever) v1 = MPEG2Source("E:\My Videos - Working On\Season 0\S01-E02 - Parallax.d2v", cpu=4, info=3).LanczosResize(768, 576) v2 = AVISource("F:\My Videos - Working On\Voyager\Season 1\S01-E02 - Parallax\S01-E02 - Parallax.avi", audio=false).ConvertToYV12() sub = v1.subtract(v2) substrong = sub.levels(112, 1.000, 144, 0, 255)
Now, I'm trying to get my scripts to work with x64 AvsPmod, AviSynth+, and VirtualDub x64.
I seem to be missing something; I get the error "Not a clip" in AvsPmod.
You need to return something. If you wanted to see "substrong" add that to the end
eg.
Code:# If Videos start at different frames use frameadjust to align them frameadjust=0 name1="Source - Parallax.d2v" name2="Vegas Output - Parallax.avi" # Videos to compare: (v1 is original, v2 is encoded or whatever) v1 = MPEG2Source("E:\My Videos - Working On\Season 0\S01-E02 - Parallax.d2v", cpu=4, info=3).LanczosResize(768, 576) v2 = AVISource("F:\My Videos - Working On\Voyager\Season 1\S01-E02 - Parallax\S01-E02 - Parallax.avi", audio=false).ConvertToYV12() sub = v1.subtract(v2) substrong = sub.levels(112, 1.000, 144, 0, 255) substrong
Best way to compare two videos (original and converted) for frame shift?
By Bencuri in forum Video ConversionReplies: 4Last Post: 27th Aug 2018, 21:06 -
Compare two frames to the same
By Megafox in forum Newbie / General discussionsReplies: 4Last Post: 9th Mar 2018, 22:51 -
How to compare between two images?
By BlurayHD in forum Video ConversionReplies: 6Last Post: 12th Feb 2018, 22:06 -
Synchronize video from 1.video and sound from 2.video using compare videos
By ad48 in forum EditingReplies: 0Last Post: 3rd Apr 2015, 06:18 -
How Can I Visually Compare Two Encodes?
By Pilotwings_64 in forum Video ConversionReplies: 10Last Post: 4th Jun 2014, 07:06
