This has happened only occasionally, and it is kind of mysterious when it happens because I don't know why. I will take what LOOKS like a decent Remux encoded MKV file, using MediaInfo, everything looking okay (level, frame rate, reframes, audio, etc...) but when I mux it using TSMuxer into a regular BDMV / CERT format and burn to Blu-ray and then try to play it on my OPPO player (an older BDP-83 PRE-Cinavia) every once in a great while the phenomenon will happen where I hear the sound just fine but the picture is blank. BUT... here is the weird part and will HOPEFULLY suggest to someone here as to why this happens, if I FF the Blu-ray disc that I burned THEN mysteriously I can see the picture FF'd just fine at 2x, etc...
So, something is causing the picture not to show at normal speed. Now, I'm no expert, but the only 'unusual' thing that I noticed in the MediaInfo file is that the subtitle (it is a French film) is in the Zlib format - It shows PGS (Zlib) I know that is some kind of compressed format and I THINK in the past that when I've seen that the subs might not show, but the picture is fine. Other than that, I couldn't guess what is causing this. I will include the MKV MediaInfo information here below.
Thanks!
General
Unique ID : 330366114953947342823180854953587014557 (0xF88A3307F3621E87EC86A38887A87B9D)
Complete name : D:\___MEDIA\File.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 10.3 GiB
Duration : 1h 21mn
Overall bit rate : 18.0 Mbps
Movie name : File
Encoded date : UTC 2018-09-21 10:38:51
Writing application : mkvmerge v26.0.0 ('In The Game') 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Attachment : Yes / Yes / Yes / Yes
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 21mn
Bit rate mode : Variable
Maximum bit rate : 35.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Title : File
Language : French
Default : No
Forced : No
DURATION : 01:21:31.095000000
NUMBER_OF_FRAMES : 117269
NUMBER_OF_BYTES : 10092461709
_STATISTICS_WRITING_APP : mkvmerge v26.0.0 ('In The Game') 64-bit
_STATISTICS_WRITING_DATE_UTC : 2018-09-21 10:38:51
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : PCM
Codec ID : A_PCM/INT/LIT
Duration : 1h 21mn
Bit rate mode : Constant
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Title : File
Language : French
Default : Yes
Forced : No
NUMBER_OF_FRAMES : 146733
NUMBER_OF_BYTES : 939090240
Text
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Title : English-PGS
Language : English
Default : Yes
Forced : Yes
DURATION : 01:16:33.235000000
NUMBER_OF_FRAMES : 892
NUMBER_OF_BYTES : 6184929
Menu
00:00:00.000 : fr:Chapitre 01
00:06:17.710 : fr:Chapitre 02
00:13:23.177 : fr:Chapitre 03
00:19:02.850 : fr:Chapitre 04
00:29:49.621 : fr:Chapitre 05
00:36:01.367 : fr:Chapitre 06
00:44:01.847 : fr:Chapitre 07
00:47:36.812 : fr:Chapitre 08
00:53:02.637 : fr:Chapitre 09
01:02:45.678 : fr:Chapitre 10
01:08:57.508 : fr:Chapitre 11
01:20:06.134 : fr:Chapitre 12
This just happened again, the same thing. Sure would be nice to be able to find out WHAT setting or whatever is causing this phenomenon...
zlib is the Matroska container compression. You can test if that is the cause by remuxing using MkvToolNix (GUI) and setting the compression for the subtitle track to "none".
Hey Sneaker, thanks man for the reply. Yeah, I DO do that also, but unfortunately that doesn't seem to have anything to do with why the video is not displaying at normal speed, but it shows at 1x, 2x FF, etc... I always have to use BDRB and re-render the damn thing by shrinking the output size a little. Which is a shame when you have a full Remux already...
Try:
In MKVToolNix GUI go Preferences -> Multiplexer -> Default values and there set additional command-line options:
--clusters-in-meta-seek --engage no_cue_duration --engage no_cue_relative_position --disable-track-statistics-tags
Restart the app and then re-mux the mkv file.
https://gitlab.com/mbunkus/mkvtoolnix/wikis/Improving-playback-compatibility-with-players
If it still doesn't work show more MediaInfo of both working and not working files. How do you create the files? -
Thanks Bro!
Yeah, I already have the two 'cue' entries (so my OPPO can FF properly) but, I will add the others.
What's even weirder is that after re-rendering the remux file with BDRB, then the resulting BDMV folder does play in the sense that I can now see the picture on my OPPO player, but it has this other phenomenon that I've also had at times and that is where the screen flashes between the scene and a green screen, and every few seconds the picture, such as it is, also pixelizes. Damn weird... Usually JUST with the green / pixelating thing, I can use an older version of TSMuxer and it fixes that (don't ask me why...) But, this time I get the one phenomenon with the straight file muxed to a BDMV folder with TSMuxer where the picture doesn't show unless FFing. Or, in this case, AFTER re-rendering the file using BDRB, the resulting BDMV folder now shows but with this 2nd phenomenon...
I'll try what you suggested and let you know. Thanks! -
Hey there! Just wanted to follow through on what I THINK the deal was... To answer Sneaker's question, basically it is taking the movie file from a full BD. BUT... I THINK that is what is the issue is! I realized this last time when the same phenomenon happened, for some reason I went back and used BDRB to IMPORT the movie playlist file and THEN burn it. Aha! When I went back and looked at the BD structure, I realized that in BDRB you could bloody TELL that the 'movie file' was actually made up of SEVERAL m2ts files! B@stards! They must do that so that if you just simply choose what appears to be the 'main movie file' because it is so large, you don't realize that you are actually leaving out a few other files that might add up to just a few Gigs!
Ahhhhhhhh.... So, as I was saying, while looking at the structure inside of BDRB, I could then SEE that to import the movie playlist, that a few other files are also selected in addition to the one that I THOUGHT was the movie m2ts! So, in this last case anyway, and I'm ASSUMING that maybe this is what has happened before, after BDRB imported the COMPLETE movie playlist, THEN I was able to burn and play it just fine
So, in always just quickly choosing the one large m2ts file and running it through TSMuxer and then burning it, at these times I was likely not getting the WHOLE movie!
So, after this, instead of doing that, which has worked I'd say about 95% of the time, I'm going to IMPORT the movie playlist using BDRB BEFORE burning it, to make sure I have the WHOLE bloody film!
At least that is what I discovered this time and I HOPE that is the answer to this very mysterious thing that has happened once in a while
Create MKV from a BDMV folder?
By elcoyoteloco in forum Blu-ray RippingReplies: 17Last Post: 4th Feb 2018, 05:06 -
Convert BDMV folder? to MKV!
By tOkyO1 in forum Blu-ray RippingReplies: 3Last Post: 3rd Feb 2018, 23:59 -
"COVER ART" on MKV file is not showing only THUMBNAIL is showing
By ChinamyLIVE in forum EditingReplies: 6Last Post: 31st Mar 2015, 10:51 -
Convert BDMV folder into individual mkv files named after titles
By kurbads in forum Blu-ray RippingReplies: 1Last Post: 21st May 2014, 21:20 -
Main Movie Not Showing In BDMV/Stream Folder
By bht4242 in forum Blu-ray RippingReplies: 5Last Post: 25th Jan 2014, 19:00
