Trying to split up a DVD I've ripped which contains episodic content.
However after loading the .cut file, setting the output and temp folders. it fails with this.
x264 call: "D:\MkvCutter\x264.exe" --profile main --level ain --tff --ref 1 --bframes 0 --weightp 0 --min-keyint 2 --keyint 14 --stitchable --non-deterministic --thread-input --crf 19 --demuxer avs --fps 25000/1000 --sar 64:45 -o "D:\ISO\1-001_reencode.264" "D:\ISO\1-001.avs"
x264 [error]: invalid argument: level = ain
Anyone encountered this one?
Cheers.
Hi and sorry my ignorance. Never heard about level ain. I thought it should be number like 4 or 4.1 and so on.
Edit can't it be some abrevation something like As I need or similar?
BernixLast edited by Bernix; 22nd Sep 2018 at 06:42. Reason: Edit
Not sure.
The full log from MKVCutter is below
MkvMerge output: Multiplexing took 29 seconds.
deleted D:\Cutting\1_mkvOptions.txt
video splitter created the following files:
1: D:\Cutting\1.mkv
mkvSplit finished,..
handling split files,...
trim value for D:\Cutting\1.mkv: Trim(0,length=26)+Trim(14,length=70898)+Trim(70914 ,length=22)
createAvisynthSkript(D:\Cutting\1.mkv, Trim(0,length=26)+Trim(14,length=70898)+Trim(70914 ,length=22))
Avisynth file name: D:\Cutting\1.avs
Saved avisynth script:
AssumeTFF()
LoadPlugin("D:\MkvCutter\ffms2.dll")
FFVideoSource("D:\Cutting\1.mkv", threads=1)
AssumeTFF()
to: D:\Cutting\1.avs
Detected settings:
AVCProfileLevel: Main@Main
Interlaced: TFF
Cabac: true
AVCRefFrames: 1
Chroma offset: 0
BFrames: 0
WeightedB: 0
WeightP: 0
Min Keyint: 2
Max Keyint: 14
QPMin: 0
AspectRatio: 1.422
SPS: -1
FPS: 25
creating x264 reencode call for: D:\Cutting\1.avs
-> x264 call: "D:\MkvCutter\x264.exe" --profile main --level ain --tff --ref 1 --bframes 0 --weightp 0 --min-keyint 2 --keyint 14 --stitchable --non-deterministic --thread-input --crf 19 --demuxer avs --fps 25000/1000 --sar 64:45 -o "D:\Cutting\1_reencode.264" "D:\Cutting\1.avs"
encoding next file,... (1 left)
ExitCode: -1, ExitStatus: 0
x264 encoding finished,..
Resetting since x264 crashed,.. -
Hi,
if it is script made by mkvcutter, try post original file mediainfo text format. It seems to me be wrong main@main. First for profile is o.k. Level AFAIK isnt main. It is number. So it can be main@L5.1. I think MKV cutter simply get info from original file create script and because the information of original file is from my view somehow wrong, so it skips first letter from Level (should be L4.1) and take rest. And rest is ain. So x264 is confused and crash.
Post some detailed mediainfo of your original file.
BernixLast edited by Bernix; 22nd Sep 2018 at 07:55. Reason: Profile exchanged to Level
This is how it looks normaly High@L3
Noticed at HEVC there is Main@L5@Main. But still level presented as number. And using mkv cutter, you are working with H.264 not with H.265 format. Presume.
Bernix
What CRF Level Do You Use?
By Anakin in forum Video ConversionReplies: 59Last Post: 21st Sep 2018, 06:07 -
Invalid Argument to function "Overlay"
By xMike in forum EditingReplies: 4Last Post: 7th Apr 2018, 10:38 -
"Invalid SRT format. "06B20BF0" is invalid timing info" error with tsMuxeR
By Jijital in forum Authoring (Blu-ray)Replies: 6Last Post: 3rd Feb 2016, 00:18 -
What Is Video Level and How To Change Video Level
By Aashik Alam in forum Video ConversionReplies: 3Last Post: 12th Jan 2016, 07:26 -
SSD just got to another level!
By newpball in forum ComputerReplies: 14Last Post: 11th Jul 2015, 18:30
