    Mar 2011
    Oregon, US
    I have version 5.38xx of VideoReDo TVSuite, when I to open a mkv file here is its media info :
    General
    Unique ID : 30157067833705510284589443503604812504 (0x16B00A3D481FBB3871405D259636CAD8)
    Complete name : M:\happy days\Season 2\[1974-09-17]∶'Series∶ 'Happy Days' ► [Season 2] [Episode 2] Episode Richie's Car.mkv
    Format : Matroska
    Format version : Version 4
    File size : 426 MiB
    Duration : 21 min 1 s
    Overall bit rate : 2 835 kb/s
    Writing application : Lavf56.30.100
    Writing library : Lavf56.30.100
    Video
    Format : AVC
    Format profile : Baseline@L3
    Format settings : 1 Ref Frames
    Format settings, CABAC : No
    Format settings, RefFrames : 1 frame
    Codec ID : V_MPEG4/ISO/AVC
    Bit rate : 2 500 kb/s
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Variable
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Writing library : x264 core 146
    Encoding settings : cabac=0 / ref=1 / deblock=1:0:0 / analyse=0x1:0x1 / me=dia / subme=1 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=2 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=abr / mbtree=0 / bitrate=2500 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Default : Yes
    Forced : No
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Format settings : Joint stereo / MS Stereo
    Codec ID : A_MPEG/L3
    Codec ID/Hint : MP3
    Bit rate mode : Constant
    Bit rate : 320 kb/s
    Channel(s) : 2 channels
    Sampling rate : 44.1 kHz
    Compression mode : Lossy
    Delay relative to video : -58 ms
    Stream size : 48.1 MiB (11%)
    Writing library : LAME3.99.5
    Default : Yes
    Forced : No
    I get this error:Click image for larger version
ID:	46759 and it bombs out
    Here is the version number :Click image for larger version
    can someone help me open without error ? John
    Mar 2008
    Strange characters in the file name/path ? Try simplifying it to see if it makes any difference
