Hi again,
So I had a bad tape jam that I outlined in my other thread where I had to take apart the unit to extract the tape. I was able to correctly put the top tape guide back into place, but two things: 1) there was a loose 3/4 inch capacitor in the box and 2) I have now noticed that the machine is not able to play tapes. It's like the motor that would turn the tape just got a lot weaker. I stuck in a newer tape and it plays with some mechanical noise but can not fast forward. I put in an old SP tape and it doesn't play at all. I'm guessing the tape that originally got jammed was wound too tight and blew the motor? Would just the blown capacitor cause that issue? I guess I will try to find someone that can repair it (washington dc suburbs - know anyone? ). I loved this thing - was my best player in the last year of digitizing. Picked up the digitizing bug a year or two ago - about 500hrs of tapes done, but this is my first broken unit. Any advice? Is there another forum where details on vcrs/repairs might be more appropriate?
Since you have the service manual, you could start by checking the voltage at the capstan motor with a meter.
It's very unusual for a JVC VCR to have caps issues.
But it can happen.
A blown motor probably has nothing to do with the caps, and the motor is simply shot.Want my help? Ask here! (not via PM!)
Thanks for the replies. What would the fix be for a blown motor? Full replacement with same model type or could the motor be serviced?
How do you know the motor is blown? It could just be a component in the motor circuit. Or even a mechanical problem in the linkage.
Jvc 720 25
By E Howland in forum Capturing and VCRReplies: 5Last Post: 6th Sep 2017, 20:42 -
Issue with Canon HV 40 Capturing BLOWN FIREWIRE?? Dv to HDV?
By ducksalot in forum Capturing and VCRReplies: 11Last Post: 26th Sep 2016, 12:27 -
JVC HR-S9700 v JVC HM-DR10000 v Panasonic NV-V8000. WHICH IS THE BEST ONE?
By VHS-C98 in forum Newbie / General discussionsReplies: 5Last Post: 16th Mar 2016, 08:40 -
Highest Quality Playback with JVC HR-S9600U
By user10495 in forum Capturing and VCRReplies: 2Last Post: 7th Mar 2015, 16:50 -
Need help with JVC SR-V10U
By bigvlad12 in forum Newbie / General discussionsReplies: 4Last Post: 8th Mar 2014, 18:15
