I am transcoding udp source to rtmp output.
After Few minutes it starts giving error likeHTML Code:ffmpeg -timeout 2000 -y -i 'udp://@239.1.3.105:8002?fifo_size=1000000\&overrun_nonfatal' -f +global_header -c:a aac -strict experimental -b:a 64000 -ar 44100 -ac 2 -ab 128k -s 640x360 -vcodec libx264 -pix_fmt yueset:v faster -r 30 -f flv 'rtmp://admin:admin@192.168.2.200:1935/live/wtvZEEANMOLCINEMA.stream'
And stream stops transcoding. I could not find the issue. I would appreciate if some one help me to solve this problem.Code:[mpegts @ 0xbbd120] PES packet size mismatch758kB time=00:03:19.97 bitrate=1055.2kbits/s [mpeg2video @ 0xe67120] ac-tex damaged at 0 35 [mpeg2video @ 0xe67120] Warning MVs not available [mpeg2video @ 0xe67120] concealing 45 DC, 45 AC, 45 MV errors in P frame udp://@239.1.3.105:8002?fifo_size=1000000\&overrun_nonfatal: Input/output error udp://@239.1.3.105:8002?fifo_size=1000000\&overrun_nonfatal: Input/output error.8kbits/s [flv @ 0xbe28c0] Failed to update header with correct duration. [flv @ 0xbe28c0] Failed to update header with correct filesize. [flv @ 0xc01b80] Failed to update header with correct duration. [flv @ 0xc01b80] Failed to update header with correct filesize.
I have attached all source script and ffmpeg log.
Results 1 to 1 of 1
Problems with transcoding to H.265 with FFmpeg
By PescaGialla in forum Video ConversionReplies: 3Last Post: 10th Apr 2018, 03:37 -
metadata not in resulting mp4 after ffmpeg NVenc transcoding
By hydra3333 in forum Video ConversionReplies: 18Last Post: 23rd Mar 2018, 22:08 -
Which codec and settings to use with FFmpeg for temporary transcoding?
By konstantinusz in forum Video ConversionReplies: 15Last Post: 4th Dec 2016, 19:07 -
Cpu meltdown transcoding with ffmpeg
By oduodui in forum Newbie / General discussionsReplies: 17Last Post: 26th Apr 2016, 19:34
