    May 2016
    Lithopolis, OH United States
    Is there a certain size that will allow me to upload a video in HD? Are alternative methods where I can use programs like Vegas or Virtualdub AIO to upload videos where Youtube has "no choice" but to make it HD? Does anyone have the answers to these questions?
  2. Anonymous
    Guest
    Unless things have changed drastically, if you upload a, let's say, 720p clip, then YouTube will generate an HD copy and lower-resolution versions as well. But it will not create a 720p or a 1080p version from a 480p source, for instance.
    May 2016
    I see. What are the solutions to this?
  4. Originally Posted by Guernsey View Post
    youtube makes the same resolution as you give it to it
    you upload 1280x720 so that is going to be youtube resolution as well and lower resolution version (480p) as well
    you upload 1920x1080 so it is going to be that resolution as well (plus 720p, 480p)
    if you have 720x480 video, it will not be posted in HD, you'd need it to upscale it yourself first and then upload
    but 720x480 is interlaced mostly, if you upscale it in Vegas , it will be messed up, you'd need to do it outside of Vegas with some sophisticated methods, to make video progressive first , then upscale to progressive again, you can try VirtualDub2. You do not want to upload intelaced video to YouTube anyway. YouTube maybe deinterlaces it, but I doubt it does better that you'd do it yourself in that VirtualDub2 for example.
    May 2016
    Looks like I have to use the VirtualDub2 as Vegas is not a thing for me right now. Will the filesize be massive if I used such a thing? I had some experience with Virtualdub and sometimes I save video files with a huge filesize due to the aforementioned upscaling and resizing.
  6. virtualdub2 can export MP4 so you can reduce your size and upload it
    May 2016
    Okay I will give that a try then.
    May 2016
    How do you resize the video? Is the same as in Virtualdub?
