I bought a DVD movie few years ago. Back then I ripped the movie only to iso. Watched & deleted. Now, 5 diff computers do not 'see' it. One comp w/o any decrypter recognized it for a while, (1-2 minutes), then it was gone. Old Slysoft does not see it anymore, New 'Redfox' also does not see it. The DVD came from:
https://www.moviesunlimited.com/movies
This disk happened to be a DVD-R, not a 'pressed' disk.
I have dvd-r disks I burned years before I bought this one which still 'work'.
Is this now designed into them??
Whats going on?
-corne-
Results 1 to 9 of 9
Yes, no, maybe, I don't know, Can you repeat the question?
I assume you have examined it physically. No spots or streaks or visible problems with it? Can you determine the brand?
Checked the media code? https://www.videohelp.com/dvdmediaform.php?dvdinfo=1#dvdinfo
I'm wondering if it's just a low quality disc and is now deteriorated. Some programs like ISOBuster may be able to recover something. -
A better reader drives usually helps more than software.
Try another drive.Want my help? Ask here! (not via PM!)
What about try *not recommended (because intensive dvd drive usage) and result unsure* recurva. It can help probably if header is wrong. Or save some VOBs. But personaly I wouldn't do it, because of really big hazzard with dvd drive. Not mentioned DVD medium itself. Probably also recurva have mechanism to not work with cd/dvd/bluray.
According to lifewire it now support cd/dvd/bd but it not used to be.
If definitely wrong idea prove it and I will delete this to avoid feature usage.
BernixLast edited by Bernix; 24th Sep 2018 at 11:40. Reason: According to ....
Panning left right sees splits through vertical objects on Eizo Monitor
By DBenz in forum Software PlayingReplies: 6Last Post: 27th Jul 2018, 07:36 -
Bluray writer no longer sees BRs, still sees DVDs.
By cal_tony in forum DVD & Blu-ray WritersReplies: 14Last Post: 11th Jul 2018, 13:51 -
How to demux a DVD that Windows sees as blank?
By VideoFanatic in forum DVD RippingReplies: 4Last Post: 7th Mar 2018, 07:21 -
Weird hard drive issue: Windows sees but bios does not
By Brainiac in forum ComputerReplies: 6Last Post: 21st Jan 2016, 14:49 -
Plugable 10-port USB: XP sees it, Win-7 does not
By Frank-0-Video in forum ComputerReplies: 20Last Post: 2nd May 2014, 15:16
