Hi all,
Sorry this isn't technically a capturing problem, but during a capture....I had a tape get stuck in my HR-9600. it was pretty bad - would not eject and the unit kept turning off. I manually got the tape out by opening the cover and then releasing the top guide. Now the problem is I can't figure out how to put the top guide back. It's kind of a complicated part...I'm just not seeing the correct alignment - any tips?
Not sure what you mean by "top guide," but perhaps the service manual will help. (Web site appears to be down as I write, but may be back up soon.)
https://elektrotanya.com/jvc_hr_s8600_s9600.pdf/download.html -
For anyone with the model, it's the metal bar that props open the top of the tape. The service manual gives instructions on how to release it with a tape jam, but not really how to put it back.
EDIT - I was finally able to get it - putting in a tape helped it make it more obvious and it kind of snapped into place with the tape there. Should have tried that earlier.Last edited by gamjerr; 20th Sep 2018 at 21:54.
ATI All-In-Wonder (AIW) 9600 AGP A/V Output Cable / TV Wonder HD600 PCI
By Eagle_FL3D in forum Capturing and VCRReplies: 23Last Post: 23rd Apr 2018, 18:09 -
JVC HR-S9700 v JVC HM-DR10000 v Panasonic NV-V8000. WHICH IS THE BEST ONE?
By VHS-C98 in forum Newbie / General discussionsReplies: 5Last Post: 16th Mar 2016, 08:40 -
New layout with a top menu
By Baldrick in forum FeedbackReplies: 34Last Post: 23rd Mar 2014, 00:28 -
Top 5 Tips to Getting The Most out of FCP X 10.1
By connerpro in forum EditingReplies: 3Last Post: 17th Feb 2014, 18:27 -
Cut off on top
By king818 in forum Newbie / General discussionsReplies: 9Last Post: 22nd Sep 2013, 20:18
