  1. Hey there.
    First of all I will give you a few details from what I have gathered and I am planning, considering, all my experience capturing is with a non-lossless capturer. What I intend to do is go ahead with a Blackmagic Intensity Pro 4K attached to my pc, which is going to get the stream from a tv-box. The problem is the destination screen, it will get very messy if I have to connect it to my living room tv, hence the question: Is there a way to make the tv-box player app stream at "max quality" without having a tv with this specs at the destination?, so it can output the best stream to be captured by the Blackmagic card.
    This would make the ideal set-up next to my pc, adding only an small display to control the tv-box menus, plays and stop.
    I have thought of an Nvidia Shield, as reproducer, but I haven't deeply read and investigated about it. If you guys think there is something better to this purpose, yes please comment too.
  2. Member Cornucopia's Avatar
    There are plenty of apps & boxes that can manage & spoof EDIDs (metadata that describes a display's specs: refresh, rez, colorspace, etc), but no device (certainly no LEGIT device) can be sold (for long) that spoofs HDCP.
  3. Originally Posted by Cornucopia View Post
    Can you please list some of the apps and boxes that can spoof EDIDs ? My intention is not to bypass the HDCP, only to have the tv-box stream at max capabilities, without having actually a 1080p/4k HDR tv, at the destination.
  4. Member Cornucopia's Avatar
    Any of the industrial AV system controller/switcher stuff (AMX, Crestron, Extron, probably even Kramer, etc) should be able to do it. Not cheap, but you have much fewer issues. I manage Extron & Crestron stuff daily.
  5. Originally Posted by P2PRepublic View Post
    Is there a way to make the tv-box player app stream at "max quality"... adding only an small display to control the tv-box menus, plays and stop.
    You can't spoof the EDID and then have the high res picture go to a low res display. You would need a scan converter for that. And if you use a scan converter you don't need to spoof anything -- the scan converter will just use its own EDID to get the high res picture.
  6. Originally Posted by jagabo View Post
    Well that's true. I didn't thought of that. It was quite obvious. My display is going to be smashed with the stream signal.
