Hello, I was wondering how those it works or how capturing made easy like me just an average girl and not too savvy in computers...
	Depends what you want to capture. Off of a satellite feed, from a video site or from a camera or other device?
 Add some more information and someone here may give you advice.
 And I also changed your thread title to better reflect your topic.
 And welcome to our forums.
	Depends on what you want to capture, VHS,Betamax, miniDV, video8, Hi8, Digital8, or video from a games console.
 Depending on which capture device you use, the video signal must be clean & stable, use a good computer, not an old "weak" one, this also depends on your capture device,
 a lot of capture devices are "old" and are not suported by the operating system of a normal pc, the interface what the capture device uses, must be also present on the computer,
 there are some video output connections, composite video, s-video component-video, HDMI.
 composite is the one that is most used, but not the best, s-video is a little better, component video is the best analog video connection, HDMI is also preseent on some of the last vcr's that where available, A vhs/dvd combo machine would be ideal for transfering vhs tapes to dvd, and is also usable as "passthrough" to a capture device, A dvr, Digital Video Recorder can also be used as a passthrough, a dvr can be one that records on dvd (optical discs) or it's one that has a harddrive to store the video on, most of the time you can also edit what you recorded.
 Capture devices can be: a USB "dongle" USB goes in the computer, the cable goes into the vcr/dvd combo or dvr, a usb dongle is cheap but does not perform all too well, a capture device can also be a "box" withe a certain interface, there are some of those....
 A capture device can be also a PCI card that sits in a computer.
 It all depends what you can afford or can get hold of, some old digital camcorders can also serve as passthrough.
 If you have only few tapes, you could search for a local photo-shop that does transfer work.
 btw "capture" here, relates to video, not a person  Last edited by Eric-jan; 23rd Sep 2018 at 08:34.
  Suggestions for capture software/new cardBy ramirezi in forum Capturing and VCRReplies: 2Last Post: 9th May 2017, 04:15
  Look for suggestions for screen capture software?By Tearren in forum ComputerReplies: 9Last Post: 27th Jul 2015, 23:04
  Need suggestions for new capture card to record composite videoBy techspark in forum Capturing and VCRReplies: 45Last Post: 15th Feb 2014, 08:38
  Refurbished Cards in Greece for VHS Capture. Suggestions?By boko in forum Capturing and VCRReplies: 2Last Post: 6th Feb 2014, 13:33
  Suggestions on Setting up a vhs captureBy boko in forum Newbie / General discussionsReplies: 7Last Post: 4th Feb 2014, 16:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
