I have a number of old VCD / DVD discs more than 10 years that I want to make a copy of them to hard drives, so as to avoid possible crack, damage or loss of the physical discs in the future.
What is the easiest way while preserving the quality as original as possible ?
I have little experience of doing this
Please suggest for me I'm a newbie
Results 1 to 10 of 10
You should start by reading the VCD tutorial on this site:
https://www.videohelp.com/vcd
Just copy files to your hard drive and use the MPEG-1 files. -
In general*, you can just copy the .dat files directly from the disc. To ensure playback and editing compatibility, convert the .dat files to .mpg with VCDEasy. There's no change in quality as .dat files are the same as .mpg (mpeg 1) with some extra info in the header which may cause issues with some (usually older) playback and editing software.
If you want to create a new VCD from the files, you'll have to create the proper VCD structure with a program like VCDEasy before burning. You could also create a DVD Video disc since 352x240 (NTSC) & 352x288 (PAL) Mpeg 1 video is supported by the DVD spec.
*There are some wildly out of spec VCDs primarily from India with copy protection that's never been cracked. I've never heard about any VCD from Asia having any type of copy protection. -
"Just copying" is not the best method for VCDs, as the mpeg files (*.DAT as authored on disc) reside in CDXA Mode2Form2 disc sectors, so if you don't properly strip off the sector overhead metadata during or immediately after ripping, you will have garbage mixed in with every sector's-worth of data copied. Garbage which can corrupt playback, or future editing/conversion.
<edit>lingyi beat me to it</>
@kenny1999, why are you still a newbie? You've been on this site for a decade. Seriously?
Scott -
DVD Decrypter to read DVD ISO.
Imgburn to read VCD, or ISOBuster to extract it.Want my help? Ask here! (not via PM!)
Yup, Imgburn all the way!
You asked essentially the same question over a year and a half ago, here: https://forum.videohelp.com/threads/382300-How-to-rip-vcd-dvd-while-preserving-the-quality-as-original-as-possible#post2475319 and here: https://forum.videohelp.com/threads/383095-what-s-the-best-software-tool-for-ripping-D...10#post2482115, were given answers: DVDFab, MakeMKV and Imgburn, but you abandoned both threads.
ImgBurn L-EC Uncorrectable Error Ripping Commercial Discs
By koberulz in forum DVD RippingReplies: 31Last Post: 29th Aug 2019, 14:38 -
Ripping and Converting VideoNow Discs
By coondog1234 in forum Video ConversionReplies: 2Last Post: 3rd Dec 2015, 13:14 -
Ripping discs and resetting region code
By whoisquilty in forum MacReplies: 2Last Post: 27th May 2014, 13:23 -
Pixma MG5000 series printing bad on DVD-R discs - any recommended discs?
By franco in forum MediaReplies: 3Last Post: 12th Mar 2014, 08:06 -
Ripping discs to MKV, full framerate.
By xtremeD63 in forum Blu-ray RippingReplies: 23Last Post: 15th Jan 2014, 14:29
