hello, i recently went to a concert and had a soundcheck experience. i had a small recorder with me to record it all. when i listened to the files when i got home the quality was absolutely terrible. is there a way to reduce the noise and make his voice more crisp? i know it won't be 100%, but i'd at least like to know what he's saying. heres a small clip.
AUDIO WARNING: START AT YOUR LOWEST VOLUME SETTING THEN WORK YOUR WAY UP. THE AUDIO IS TERRIBLY LOUD
https://drive.google.com/open?id=1y-0lKTMjimDvk_DJrVEcnz1uRMB7CVXT
orig file is a .wav file
Results 1 to 9 of 9
fifalwt91 Probably a breach of copyright but having said that there is no way you can improve it. To get good sound you need an output from the mixing desk not waving this or that bit of domestic recorder in the air above you. Chuck it...
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
For those who know what they're doing, in-audience concert recording (bootleg or not) can be a very high quality, natural experience. All depends on placement, method, equipment, settings, skill.
Didn't listen, but if jagabo says it's bad, it's bad. And if it's "bad", best you could improve it would be to "poor".
Scott -
Highly distorted, no balance between voice?? and what sounds like a highly distorted guitar?? chords. Nothing there to "improve" I've heard a bootleg acoustic recording of Dame Nellie Melba recorded from the flies above the stage that sounds better and that's from an Edison cylinder
Way too much clipping. Basically your audio was recorded so loud that it just records the wav with amplitude peaks that are flat, as it can't go any higher. Normal audio should look like nice sine waves with rounded peaks. Maybe you've seen audio equipment with dB gauges and when it gets loud the gauge goes into the red. Well this audio would be in the red nearly nonstop. Nothing can really be done to help it. You can look at your audio in something like Audacity.
The photography equivalent would be like taking a picture of the sun. Without proper precautions you're just going to get an all white picture. No hope of getting any detail. -
Removing or reducing pixelation
By CM120884 in forum EditingReplies: 6Last Post: 11th Apr 2018, 18:09 -
ffmpeg noise filter usage based on mplayer noise settings?
By Selur in forum Video ConversionReplies: 5Last Post: 21st Jun 2015, 09:19 -
Reducing dimension size
By rdeffley in forum RestorationReplies: 5Last Post: 20th Dec 2014, 14:03 -
PSU fan spins way too fast making terrible noise.
By Atotaloss in forum LinuxReplies: 6Last Post: 17th Jun 2014, 09:49 -
What about reducing necro posting?
By bat999 in forum FeedbackReplies: 16Last Post: 16th May 2014, 00:30
