Good day,everyone.
I'm trying to extract an audio from a HLS stream with FFMPEG, although the console shows that it extracted it full length, the extracted audio is only half long of that.
FFMPEG input:
After file is extracted this is what appears on commandline:Code:ffmpeg -i http://192.168.1.104/root/media/hdd/recordings/recording_09_09_2018_14_33_My_Recording.ts.m3u8 -vn -acodec copy outputaudio.aac
The file is exact size as mentioned,however the duration is only 2h 20min,which means that there are the 2h 18min missing here.Code:size= 391131kB time=04:38:00.12 bitrate= 192.1kbits/s speed=5.28x video:0kB audio:391131kB subtitle:0kB other streams:0kB global headers:0kB muxin g overhead: 0.000000%
I tried playing the stream in VLC to double check and can confirm that actual duration is 4h 38min.
For some weird reason when i try extracting video with audio,FFMPEG messes up the whole audio and dramatically lowers it's quality (even tho i have added the -acodec copy option with it),but it extracts it full length. That's why i need to extract the audio separately.
Could this be related to FFMPEG having some issues with AAC codec?
Any tips appreciated.
Edit: I discovered that for some reason FFMPEG changes framerate from 25 (that's in original stream) to 48.something. I don't know why.
Results 1 to 1 of 1
Which "demux" program extracts audio & video from various file formats?
By jaibubwan in forum EditingReplies: 11Last Post: 18th Oct 2017, 15:20 -
Audio changes length?
By chibear in forum AudioReplies: 2Last Post: 13th Sep 2016, 18:57 -
[SOLVED] Why does ffmpeg keep going past the length of the video?
By yetanotherlogin in forum EditingReplies: 4Last Post: 23rd Feb 2016, 09:47 -
merging audio and video of different length
By Freelife2345 in forum AudioReplies: 15Last Post: 20th Nov 2014, 02:55 -
MKVcleaver only extracts video and audio tracks as unknown file types
By Teemo in forum Video ConversionReplies: 2Last Post: 19th Jan 2014, 08:29
