Hi!
I have this soft called virtualdub batcher v13 and i used to use it to batch covert videos but i haven't used it for a long time , and now i seem to forgot how to use it. All i remember is i used virtualdub to set my processing settings then save it and open the batcher load the videos and load the pocessing setting.
But that is not working because when i am saving my processing setting of virtualdub it saves a file called .vdscript and the file i have to load in the batcher program uses a .vcf file. So my question to you is how do i go about it.
It would be a great help. Thanks all the same.
vcf is the same as vdscript, you can just rename it.
But maybe you can forget batcher, in vd2 I optimized some usage of batch processing. There is batch wizard where you can add multiple files at once. -
Thanks, Shekh.
For taking the time in replying to my query. Your info on .vdscript and .vcf being the same was helpful and merely changing the name worked for me, thank you.
I have downloaded vd2 as you suggested but, I wanted to know if there is a How to use or Instruction manual on tips and tricks is available on the subject also.
Take care and thanks again for your kindness. -
No manual, but if you scroll through changes history it should give some hints.
Virtualdub Batch Question
By thecoreyburton in forum Newbie / General discussionsReplies: 7Last Post: 3rd Jan 2017, 22:25 -
VirtualDub Batch Conversation with MTS files?
By khan.cross in forum Video ConversionReplies: 2Last Post: 24th May 2015, 02:09 -
VCDGear - How to do batch conversion?
By Rexkh in forum Video ConversionReplies: 20Last Post: 16th Nov 2013, 09:50 -
VCDGear - How to do batch conversion? (Need more Help)
By Rexkh in forum Video ConversionReplies: 1Last Post: 15th Nov 2013, 01:00
