Is there a better way to load a TS file into AVISynth? I made one from a very large MKV file because I could not load it. The TS file plays, but the sound plays for a second or so before the video plays. Is there a fix for this?
FFMS2 loads but like I said the sync is off. FFmpegsource2 is taking way too long so I just give up after 20 minutes.
What do you mean too long? FFMS2 is quite a fast frame server, but it does take a number of minutes in the beginning to create
the index.
Perhaps try LSMASHVideoSource / LWLibavVideoSource -
Yes, the first time ffms2 opens a file it builds an index and can take quite a while. Subsequent openings of the file don't take too long as the same index file is used. LSMASH is similar. But sometimes one works better than the other.
Okay, I discovered the issue, the video loads fine, but the audio causes infinite loading for some reason. I've tried using the
andatrack=-1.FFCopyrightInfringement
Is there another way I can get the audio to load?
Problem With Audio Syncing
By OCG in forum AudioReplies: 0Last Post: 1st Feb 2018, 12:00 -
Need help with syncing subtitle text
By jarod1005 in forum SubtitleReplies: 6Last Post: 5th Sep 2017, 19:48 -
Syncing Subs
By bartkrn in forum SubtitleReplies: 0Last Post: 21st Jun 2016, 13:02 -
syncing sound automatically
By arjenvdm in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2015, 01:38 -
avisynth - How to write avisynth script for rgba overlay
By moelover in forum EditingReplies: 3Last Post: 13th Apr 2014, 12:24
