I found comments online about that though the maximum capacity of a DVD is 4.3GB, you should't burn it fully, but leave a small empty space. Is this correct? If yes, what is the recommended maximum amount I should burn?
Results 1 to 18 of 18
4480mb is the max, but if your worried about recovery etc do 4096mb and use multipar to make recovery info. That way in the event of a error you can get your files back...usually. I do this with pretty much all the dics I author with 5-10% redundancy. Just writing less really does nothing as a scratch is well a scratch at the end of the day
if all else fails read the manual -
Anything over 4gb is suspect, as disc edges don't always burn well even on the best media.
I generally stop at 4.25gb, never filling entire 4.37gb.Want my help? Ask here! (not via PM!)
Yes, get these:
https://www.amazon.com/Verbatim-4-7GB-Recordable-Media-Disc/dp/B003ZDNZSS
https://www.amazon.com/Verbatim-DVD-R-4-7GB-Recordable-Media/dp/B003ZDNZT2
https://www.amazon.com/dp/B00081A2KY
https://www.amazon.com/dp/B00081A2KE
https://www.amazon.com/Verbatim-DVD-R-4-7GB-8X-DigitalMovie/dp/B0001LS35M
Do not get the "Life Series" by the same company. Make sure they say "Azo" on the outside. -
+1
I recently posted this on another thread:
Read the posts on these links for the latest discussions about Vebatim AZO (and how to recognize fakes) and Taiyo Yuden:
https://forum.videohelp.com/threads/389210-CMC-manufacturing-Taiyo-Yuden-DVDs
https://forum.videohelp.com/threads/391272-Beware-of-new-Verbatim-non-AZO-packaging
Also, don't be mislead by M-Disc claims of quality and longevity. All reviews point to it just being marketing. Stick with Verbatim AZO and Taiyo Yuden." -
A DVD-R SL has 2'298'496 sectors, means 4'707'319'808 Bytes = 4'596'992 kiB = 4'489 MiB = 4.384 GiB = 4.707 GB
A DVD+R SL has 2'295'104 sectors, means 4'700'372'992 Bytes = 4'590'208 kiB = 4'483 MiB = 4.378 GiB = 4.700 GB
It is good practice to fill the discs not more than 90% for the reasons mentioned in the posts before. -
I have never had issues with how much gets burned. When I get the message (however worded) data is more than disk capacity, I remove the minimum amount to be under disk cap. I also set burn speed way below the disk advertised write speed.
Yes, no, maybe, I don't know, Can you repeat the question? -
Cannot confirm, and that's lots of wasted space imo (more than 400 MiB!).
Pretty much every DVD I ever encoded myself uses the capacity of the media by almost 100%. On a DVD+R I never come up with less than 4460 MiB out of the available 4482.25 MiB.
Never, in all those years, had problems with the last parts of the video skipping or so. I use Verbatim DVD+R AZO made in Taiwan (the Indian ones are way inferior, avoid those), and burn with my BenQ DW 1650 at half the rated media speed (usually 8x).Last edited by Skiller; 11th Jan 2019 at 19:11.
VSO inspector works
and there's 4 more listed here - https://www.raymond.cc/blog/test-cd-or-dvd-readability-by-running-surface-scan-and-file-test/ -
According to the Verbatim web site some DataLifePlus DVDs also use the AZO recording dye. I’ve been buying 16x DVD+R 50 pack in the clear container for years and have had no problems. They have an 82% 5 star rating on Amazon. Made in Taiwan. Product #94917
All this discussion thus far has been centered on 4.7 GB DVD's. What is the consensus thought on DL 8.5 GB DVD's? An obvious cursory glance by a noobie such as myself thinks, "Perfect! Twice the storage!". But are they reliable? Or are they problematic?
You are unfortunately running into a discussion about ancient technology....well almost.
We may as well be discussing who makes the best blank audio cassettes....Maxell, TDK or BASF.
Databases and lengthy discussions about the best blank DVD manufacturers and brands have been abandoned years ago....now it's a crap shoot.
Just grab some Verbatim and hope for the best.
Making a home video dvd from files on my phone but no sound on burnt DVD?
By Dannyboy1985 in forum Newbie / General discussionsReplies: 8Last Post: 19th May 2017, 16:23 -
POTPLAYER - limit amount of context menu items
By skribby in forum Software PlayingReplies: 10Last Post: 7th Jun 2015, 08:00 -
TMPGEnc Authoring Works: increase the maximum size of the DVD
By mapomme1108 in forum Authoring (DVD)Replies: 5Last Post: 13th Dec 2014, 04:46 -
Burnt DVD Freezes
By Erik419 in forum Newbie / General discussionsReplies: 12Last Post: 6th Mar 2014, 13:40 -
The maximum length of video on a DVD
By jix in forum Video ConversionReplies: 32Last Post: 20th Sep 2013, 01:37
