This is a small tutorial showing how is done.
1. Get mp4box
2. Get the track ID of the subtitle(s)
3. Track ID 3 and 4 are the subtitles, remove with:Code:mp4box -info sample.mp4 * Movie Info * Timescale 1000 - 4 tracks Computed Duration 00:02:55.427 - Indicated Duration 00:02:55.427 Fragmented File: no File suitable for progressive download (moov before mdat) File Brand isom - version 512 Compatible brands: isom iso2 avc1 mp41 Created: UNKNOWN DATE Modified: UNKNOWN DATE File has root IOD (9 bytes) Scene PL 0xff - Graphics PL 0xff - OD PL 0xff Visual PL: ISO Reserved Profile (0x15) Audio PL: AAC Profile @ Level 2 (0x29) No streams included in root OD iTunes Info: Name: If I Can't Have You Artist: Yvonne Elliman Album: Solo Night Writer: Barry, Robin and Maurice Gibb Album Artist: Yvonne Elliman Genre: Disco, Pop Created: 1978 Encoder Software: Lavf58.17.101 1 UDTA types: meta (1) Track # 1 Info - TrackID 1 - TimeScale 5000000 Media Duration 00:02:55.374 - Indicated Duration 00:02:55.374 Track has 1 edit lists: track duration is 00:02:55.375 Media Info: Language "Undetermined (und)" - Type "vide:avc1" - 5256 samples Visual Track layout: x=0 y=0 width=960 height=720 MPEG-4 Config: Visual Stream - ObjectTypeIndication 0x21 AVC/H264 Video - Visual Size 960 x 720 AVC Info: 1 SPS - 1 PPS - Profile High @ Level 3.1 NAL Unit length bits: 32 Pixel Aspect Ratio 1:1 - Indicated track size 960 x 720 Chroma format YUV 4:2:0 - Luma bit depth 8 - chroma bit depth 8 SPS#1 hash: EF179CBACC7085F90F1CA38E633ED0C376173C64 PPS#1 hash: 57B6A76E3C7BFCCAEFC8060C61076BBA234904B3 Self-synchronized RFC6381 Codec Parameters: avc1.64001F Average GOP length: 47 samples Track # 2 Info - TrackID 2 - TimeScale 44100 Media Duration 00:02:55.426 - Indicated Duration 00:02:55.426 Track has 1 edit lists: track duration is 00:02:55.427 Media Info: Language "English (eng)" - Type "soun:mp4a" - 7555 samples MPEG-4 Config: Audio Stream - ObjectTypeIndication 0x40 MPEG-4 Audio AAC LC - 2 Channel(s) - SampleRate 44100 Synchronized on stream 1 RFC6381 Codec Parameters: mp4a.40.2 Alternate Group ID 1 All samples are sync Track # 3 Info - TrackID 3 - TimeScale 1000 Media Duration 00:02:53.250 - Indicated Duration 00:02:53.250 Media Info: Language "Portuguese (por)" - Type "text:tx3g" - 77 samples Unknown Text Stream Size 960 x 720 - Translation X=0 Y=0 - Layer 0 RFC6381 Codec Parameters: tx3g All samples are sync Track # 4 Info - TrackID 4 - TimeScale 1000 Media Duration 00:02:53.250 - Indicated Duration 00:02:53.250 Media Info: Language "English (eng)" - Type "text:tx3g" - 77 samples Unknown Text Stream Size 960 x 720 - Translation X=0 Y=0 - Layer 0 RFC6381 Codec Parameters: tx3g All samples are sync
4. Done.Code:mp4box -rem 3 sample.mp4 Removing track ID 3 Saving sample.mp4: 0.500 secs Interleaving mp4box -rem 4 sample.mp4 Removing track ID 4 Saving sample.mp4: 0.500 secs Interleaving
Results 1 to 1 of 1
Need to join several MP4 files - mp4box or ffmpeg? Or neither?
By Cyber Akuma in forum Newbie / General discussionsReplies: 0Last Post: 17th Jul 2017, 16:25 -
MP4Box: How to extract a given part of a mp4 video
By semantics in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2017, 18:38 -
Anyone know how to join mp4 clips by My MP4Box GUI ?
By kwanami in forum EditingReplies: 2Last Post: 26th May 2016, 04:33 -
Linux Splitting Mp4 Video using Mp4Box
By baoky in forum Newbie / General discussionsReplies: 0Last Post: 13th Sep 2014, 01:28 -
Help about changing aspect ratio of .mp4 without re-encoding using mp4box
By zakk in forum Video ConversionReplies: 2Last Post: 24th Jun 2014, 14:39
