I have recently gotten my hands on a 1080i video which I intend to watch with the best possible presentation. By that I mean I am hoping to find a media player whose deinterlacer is as impeccable as 2018 technology can render. In truth, I had expected this to be a long-solved issue, and indeed I have had great luck with deinterlacing whenever watching 480i content, or so I thought
But within seconds of playing the video in either VLC or MPC-HC, I noticed the kind of artifacts that suggested that either no deinterlacing was taking place, or it was simply failing to achieve what I am confident can be achieved. Rapid movement spots like moving mouths or blinking eyes were regularly being shown with interlacing, even as frame-by-frame.
This led me to this helpful post from a decade ago. In it, the author provides a sample 1080i video along with many detailed explanations on how to identify the type of deinterlacer a given playback device may be using. Through the use of this post and the provided video, I was able to determine a few things:
- In 2009 at least, vector adaptive deinterlacing seems to have been the clear winner.
- Based on the artifacting I saw, MPC-HC (MadVR) quite clearly uses motion adaptive deinteralcing.
- Based on the artifacting I saw, VLC (Yadif 2x) quite clearly uses either adaptive or bob deinterlacing. (Permanent flickering even when not in motion.)
- Vector adaptive deinterlacing is not in evidence in either case.
If I prove unable to find a vector adaptive deinterlacing solution today in 2018, MPC-HC is the obvious choice between these two players in their default configurations. But I am obviously hoping for better.
Results 1 to 9 of 9
I am familiar with QTGMC, having made use of it in a few of my own home video projects. As you likely know, it is not well-suited for the realtime demands of a media player. I'm not hoping for a miracle. I'm hoping for a media player that can do at least what was possible ten years ago.
It's in the post I gave a link to above. But here is a direct link.
A test pattern like that isn't really indicative of deinterlacing quality. And that video isn't really interlaced, it's 30p with the fields out of phase. Play it with:
Code:SeparateFields() Trim(1,0) Weave()
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21 -
Why 16:9 "Original" & 16:9 "Full" settings on Blu-Ray player....?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Apr 2015, 08:13 -
Can Someone Recommend a Blu-Ray Player that can read "BD-R" & "DVD-R" ?
By THEBDC in forum DVD & Blu-ray PlayersReplies: 6Last Post: 17th Mar 2015, 17:03 -
Any problems installing "ffdshow" and "haali media splitter"?
By mks in forum EditingReplies: 19Last Post: 23rd Nov 2014, 03:16 -
[Help] Problems with the "Title Button" in the "VTS ROOT" and "VTS Normal"
By kirous in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2014, 12:31
