Personal ... kaspersky total security 18.0.0.405 is reporting viruses on the PotPlayer program, see:
File: C: \ Program Files (x86) \ DAUM \ PotPlayer \ PotPlayer.dll
Object Name: Trojan.Win32.Inject.akgvp
Type of Item: Trojan Horses
Time: Today 09/06/2018 18:11
What to do ? There are already two updates, the previous one and the one that the antivirus accuses with virus.
Results 1 to 19 of 19
try virustotal.com with this file, what other antiviruses say. By definition of spyware, there actually was K also spyware at some times. Probably it changes but Spyware search and destroy detects it on this defined rules.
Edit - Also not update each beta when software works without problem. Can be false positive. Don't know, do not use beta version with potplayer.
BernixLast edited by Bernix; 6th Sep 2018 at 18:03. Reason: Edit
Version 1.7.14255 and 1.7.14283 infected.......VERSION 1.7.14222 NOT INFECTED.
https://www.virustotal.com/#/file/13a61892fa5e8df7ed1e108b8440cd01f481b3be0cf71377ad5f...4147/detection
Kaspersky
ZoneAlarm
Trojan.Win32.Inject.akgvpLast edited by Franckdf; 6th Sep 2018 at 18:28.
Weird is it has same name. Probably they shared their db, and it is mistake. Usualy as far as I think
same virus has different name in different AV software. But can be wrong. Also do not believe kakao should hazard with its name. But of course everything is possible one bad employe and problem is there. Remember ccleaner affair.
Try 64 bit version.
BernixLast edited by Bernix; 6th Sep 2018 at 18:25. Reason: used plural
Also you are only person on virustotal who tested this file. Probably it is unique file on your computer, or nobody else tested it here. But it is less probably. Don't know.
2/66 detect "something" so it's most likely a false positive.
I'd be more concerned about having that infection Kaspersky on my computer. It's probably infected with Novichok and spying on your every button press.Last edited by mike20021969; 7th Sep 2018 at 03:28.
For me the problem is that after the installation of the last two beta updates, the antivirus already says that the potplayer is hacked and no longer use the player, just coming back to update 1.7.1422, so I do not know how to be a false positive by barring the program altogether.
I'm not wanting discord, just reporting what is going on here with the player, which I use almost from the beginning.
Kaspersky
Rising
Trojan.Inject!8.103 (CLOUD)
ZoneAlarm
Ad-Aware
Clean -
Hello dear all.
Do you know if it's safe to update the program automatically, using the program itself for searching the updates?
Should we block ( is this even possible ?) any update ( like using a firewall, for example ) if the program asks for it?
Or the problem is concerned only if I get the files available for downloading links, like here on Videohelp or even the official program homepage?
Plus: 32 and 64 bits versions have issues? Or only one of them?
---> https://virusscan.jotti.org/pt-BR/filescanjob/3474hir80s ( 64 bits )
---> https://www.virustotal.com/#/file/218729c808f87fb889226c94f365e5d53c5e0142ec4117b6427f...5922/detection ( 64 bits )
Thanks for your tips.
Best regards.Last edited by devilcoelhodog; 7th Sep 2018 at 10:29.
@devilcoelhodog
It update just full version by default. No betas. Check first think in preference first tab. This is what you are looking for.
As Lance corporal Jones would say "Don't panic"
Now is it 3/65 but it is still beta version. Also is it sure, that file can't be infected on PC itselfs? I'm nor security specialist, but can't this file be target for some attack? Potplayer is widely spread, so can't it be target?
BernixLast edited by Bernix; 7th Sep 2018 at 10:40. Reason: something to add
Hello, dear all.
Developers ( trusted ones ) that work on PotPlayer program are aware about this problem? They were notified by someone? Some fix on the way to correct such problem?Also do not believe kakao should hazard with its name. But of course everything is possible one bad employe and problem is there
Best regards. -
Hi,
if you want to inform them there is nothing easiest. Just sign in their forum.
I still think it is false positive. Altough now another one is for it is virus. But gigant like eset, bitdefender, avast, windows defender and others seems do not detect this file.
So sign in and inform them if you want.
https://potplayer.daum.net/forum/
Bernix -
Hi everyone, uploading the notifications ... I did not want the player to be infected by viruses.
I can not "log in" to the player's forum.
Kaspersky
Rising
Tencent
Win32.Trojan.Inject.Htck
ZoneAlarm
Trojan.Win32.Inject.akgvp -
I use the latest stable x64 version and kaspersky internet security and had no problem.
As Kaspersky user, you can also submit file for further examination. False positive isn't uncommon. So try to submit it here. They promise they will look closer. I do not use Kaspersky. There are AV solution that do not let you install almost nothing. Probably I'm mad, but i stay with WD and no need any extra protection. Protection or security using internet or in real life is illusion.
You can't have any problem to login to the forum. Post it here you will not achieve nothing. Try a) potplayer forum (you have to be registered b) notify Kaspersky.
BernixLast edited by Bernix; 8th Sep 2018 at 08:26. Reason: add some options
Do you think this file has a virus?
By jimdagys in forum ComputerReplies: 8Last Post: 11th Dec 2017, 00:13 -
How do virus act?
By jyeh74 in forum ComputerReplies: 9Last Post: 28th Mar 2017, 23:30 -
Avidemux and anti virus
By Anonymous in forum Newbie / General discussionsReplies: 3Last Post: 16th Mar 2017, 12:22 -
daum.net potplayer vs dvbsupport.net potplayer
By Binyul in forum Software PlayingReplies: 1Last Post: 12th May 2014, 10:45 -
WinXP died, virus or what?
By bevills1 in forum ComputerReplies: 39Last Post: 24th Oct 2013, 13:35
