Hey all, first post here. I do wedding videos, and we currently use 3 A600s and 1 A6500 with various lenses. I want to pick up a couple cameras we can set around the ceremony and reception areas to just start to go to capture random footage. Currently we are using 2 small home camcorders for this. They fine when the area is brightly lit, but with any darkness, the footage it useless. We picked up a Mevo to test out, and the quality is just horrid.
I am looking at a couple RX100s. Everything I have read about them is positive (we do photography also and would be a great camera to just have in the bag in case of emergencies). My only hesitation is this. The A6000s have a 20 minute cut off on them, where they will stop recording after 20 minutes. I know and understanding the reasoning behind this, but I need to know if the RX100 has the same thing on it before I buy one, or do they have continual recording until they are manually stopped.
Any help with this would be greatly appreciated.
Is it this camera?
https://www.bhphotovideo.com/c/product/869238-REG/Sony_DSC_RX100_Digital_Camera.html
There is written video up to 29 min. But don't know if because capacity or because overheating of camera itselfs.
Bernix -
After using DSLRs for a number of years I've come to the conclusion that video cameras work better for shooting videos. There is no file length limit, and they are ergonomically designed for that purpose. Sony (and Canon and Panasonic) have a number of good choices at various price points.
What about this. But it is just blind shot on the edge of your budget. But it has Back Iluminated sensor and in review there is it is good for low light. BI sensor should be better for this purpose. Probably smrpix will check specs and will say is or isn't good enough.
panasonic hc v770 full hd camcorder
But it is only Full HD... And at max resolution x FPS it is 50 Mb/s so it should take long clips.
Bernix -
Question about looping videos on the Sony PS3
By Bruce Wayne in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st May 2016, 03:20 -
Best TV to play video shot by Canon G7X or sony rx100?
By nathancooke in forum Newbie / General discussionsReplies: 6Last Post: 23rd Nov 2014, 17:04 -
Render time on sony vegas pro question
By bigbangnet in forum EditingReplies: 5Last Post: 24th Jul 2014, 19:47 -
GoPro (vs Sony VX2000 vs Sony RX100)
By dennismv in forum Newbie / General discussionsReplies: 5Last Post: 6th Apr 2014, 11:02 -
SONY VEGAS - Font and FX Templates Question
By PantherX in forum EditingReplies: 15Last Post: 13th Nov 2013, 15:14
