  1. Hello. I wish to use the "standard" pixel shaders that come with MPC-BE (Sharpen Complex 2, for example). Can these shaders be run with integrated graphcis?
    I know there are shaders such as MadVR which really need a dedicated graphics card, but not sure about the "standard" pixel shaders that are included in the install.
    If it makes a difference, the CPU will be an Intel i3 or i5 Coffee Lake.
    Thanks.
  2. Yes. You can use the shaders with your integrated graphics. I can use them on my old i5 2500K.
  3. Thanks, good to know. If I could ask one more question, can you remember which renderer you used with the IG? Was it VMR9(renderless) by any chance?
    But thanks again.
  4. To use the shaders I have to use Sync Video Renderer or Enhanced Video Renderer (custom presenter).
  5. Thanks a lot for the info, very useful
