Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 14 of 14
    Aug 2018
    USA
    Is there a 64-bit version of ef_barrel.vdf?
    Running into memory allocation errors in the 32-bit version of VDub2 prompted this question. The error happens when trying to save an MP4 from a 12MP image sequence.
    Edit:
    The only way I don't hit the error in the 32-bit version is by setting the 264 codec to 'Ultrafast' and limiting the amount of filters used.
  2. I think it's only 32bit , but the sources are available, so theoretically someone could compile it for 64bit
    http://emiliano.deepabyss.org/
    Another option is defish_mt x64 in avisynth , or other applications that have lens distortion filters (e.g. natron)
    But what other filters are being used ? There might be equivalents in avisynth or other programs
    Aug 2018
    USA
    Hm.. crop, 6-axis color correction, and temporal smoother..
    Would I link AviSynth into VirtualDub2? Or..
  4. Originally Posted by MFZ View Post
    Those other ones are native filters and can be found in the x64 vdub2 version
    But you can crop in avisynth too, and there are various temporal smoothing filters available as well (ttempsmooth would probably be the closes to vdub's temporal smoother)
    vdub2 has avisynth support , you can open an avs script directly as if it were a video
    Aug 2018
    USA
    Thanks for the info. I'll keep it in mind.
    I got it to do what I wanted though by checking 'Zero Latency' in the x264 codec configuration.. but why would that use less memory?
    Aug 2018
    USA
    I just verified that this command line switch: --tune zerolatency, is what makes the encoder use less memory. I'm still curious as to why though..
  7. Originally Posted by MFZ View Post
    zero latency means --bframes 0 --force-cfr --no-mbtree --sync-lookahead 0 --sliced-threads --rc-lookahead 0
    It uses less memory because of no lookahead, no mbtree, no bframes . This usually means lower compression efficiency, lower quality .
  8. Another workaround you might be able to use is frameserve from the 32bit vdub to another 64bit application, even another vdub2 x64 instance. That should workaround the memory issues
    Aug 2018
    USA
    This info is highly useful!
    Aug 2018
    USA
    I'm gettin' AVI Import Filter Error 80040154. I installed AviSynth.. It works if I open the vdf file with the 32-bit version of VDub, but that's pointless, LOL..
  11. It works here 32bit vdub2 to 64bit vdub2 . The vdub frameserver doesn't use avisynth
    Did you run the auxsetup ? You might have to merge the frameserver64.reg version
    Aug 2018
    USA
    It works. I didn't have all the auxsetup files in the main directory. They came in a directory called extra.
    I'm assuming the slower rendering FPS is to be expected?
    Thanks for coachin' me thru this by the way!
  13. Yes it's expected to be slow. Lots of overhead . If you can use separate drives for source / destination that would help
    At least it doesn't crash , and a working workaround - until you can get someone to compile an x64 version of ef_barrel.vdf for you
    Or another workaround would be to split the processes up by applying the filters to a lossless intermediate first, then encode the intermediate later, but you would need lots of HDD temp space
    I bet the defish_mt method would much faster; definitely a more tidy workflow
    Aug 2018
    USA
    I see.. Yea, it's a workaround.
    I may try that outta curiosity.
    Without a doubt, LOL..
    So, to recap.. One actual workaround for using 32-bit filters in a 64-bit environment is to frameserve from VDub 32-bit to VDub 64-bit.
