Hi I have the new Avermedia,
But i'm running into some problems with it may AverMedia live gamer 4k GC573.
And I was wondering if some else has had these problems and knows what it could be?
I'm starting to think its a vaulty unit.
Have windows 10 machine connected and I'm getting the following Problems.
- At the startup of the stream +/- 4 minutes everything works.
- then I will get random lost signal for 1 sec and the signal comes back.
- After some time the signal will be lost completely. (I will see the message from AverMedia No Signal.)
- Also Some times I get a HDCP error will streaming nothing that could trigger HDCP.
also this has happend.
Strange colours: https://photos.app.goo.gl/XvSqXkfgxKidyf1KA
A reboot of the stream machine temporary fixes the problems for a few minutes.
have tried different HDMI cables and different stream pc and older drivers.
but nothing seems to work.
Does anyone have a suggestion?
with kind regards
Sjoerd
Hi,
have you read min. specs that are required, have you it in right slot PCIe revision 2x4? Also there is mentioned that HDCP not supported with this card. But if you get this notice and you are 100% sure it is without HDCP then it is strange.
Bernix -
have tried the following motherboards.
Asus Rampage III and I7 980x
and pc with Asus Rampage IV and Intel Core i7-3970X
and planning to try it on my game pc with a MSI X299 SLI PLUS with a i7 7820X.
Just received a beta driver and i'm testing that at the moment.
my first looks like some problems are fixed.
Just trying to stream 1080p 60 Mhz not even 4k
Add the moment just getting No Signal and random Freezes.
put I a lot better than the other driver version. -
Could you tell if this capturer is capable to record multichannel audio? I have read it's only capable to output h.264+AAC and h.265+AAC, anyways it says supports 5.1 and 7.1 audio pass-through.
System requirements for AVerMedia Live Gamer Portable
By kosmaspar in forum Capturing and VCRReplies: 0Last Post: 26th May 2017, 19:32 -
Having problems with my Avermedia Live Gamer Portable.
By Masteroliw in forum Capturing and VCRReplies: 9Last Post: 18th Feb 2015, 05:00 -
By iHaz3Monitors in forum Capturing and VCRReplies: 11Last Post: 10th May 2014, 22:06 -
AverMedia Live Gamer Porable No Signal (Help Please!)
By AtricSky in forum Capturing and VCRReplies: 3Last Post: 5th May 2014, 01:37
