Hi,
I have two video files (.MKV and .AVI) which I'd like to convert to regular DVD format (pardon my layman terminology), to play on nearly any DVD player, and without any logo/watermark. May I do so for instance using VLC player and/or Windows Media Player? If indeed, how may I go about it? Otherwise, which other software would I need?
I'd appreciate some guidance/advice.
Thanks in advance!
				Results 1 to 9 of 9
	Yes. You find them by clicking on the link in the names.Are these two absolutely free?
	Neither will do any logo removing. You'll have to either edit an AVS script they create before reencoding, or create your own AviSynth script to reencode it (or do the logo removal within VDub) before making menus (if desired) and authoring for DVD.
 Logo removal is tricky and I know of no program that will do it automatically. Since you're asking some really basic questions, I might suggest forgetting about logo removal.
  Unexpected watermark in timelapse from my 80D - do you know the logo?By larioso in forum Video ConversionReplies: 7Last Post: 27th Dec 2017, 10:06
  Drop Shadows effect on watermark logo?By TheCage in forum EditingReplies: 6Last Post: 8th Apr 2016, 07:13
  Video Newbie needs ultra basic help...please! Converting mkv files.By six-h in forum DVD RippingReplies: 6Last Post: 19th Aug 2014, 18:54
  Add logo or watermark quickly without affecting video file size or qualityBy MGadAllah in forum EditingReplies: 29Last Post: 27th Jul 2014, 10:38
  Converting Mkv to Xvid/Avi in order to play desktop DVD playerBy zsbacsi in forum Video ConversionReplies: 1Last Post: 1st Jan 2014, 09:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
