Something like this but with S-video. https://www.amazon.com/gp/product/B079RCW197
Results 1 to 10 of 10
Thanks, the KDV-5000 is what I'm looking for but at $159. It'll probably be a better deal to get the KDV-7000 at $55 and use $104 savings to purchase a HDMI capture. Unless I can find something similar to KDV-5000 at a cheaper price. I think most of their products are re branded, maybe I'll get lucky.
Usual advice is to capture in native format and use the media player to convert, what is your end result.?
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Is the DVD end result as you need to give to a family member? I would convert to Divx or MKV and they can just play via a usb stick depending on their hardware.
Most ntsc<>pal boxes are poor compared to a native format capture and software conversion, I believe the free TMPG encoder will do it. http://www.tmpgenc.net/en/download.html
or buy the tmpg http://tmpgenc.pegasys-inc.com/en/product/taw6.htmlPAL/NTSC problem solver.
You can hack the DVD player to playback any region code disc and make DVD's from your DV files in the same color standard, converting from a standard to another is almost half of the video quality is lost. And if you can avoid DV from the start that's another benefit assuming you are capturing VHS tapes.
Do HDTVs handle signals better than converter box?
By Aldbaran in forum DVB / IPTVReplies: 18Last Post: 17th Oct 2017, 18:15 -
Does Toshiba DVR620 work with a TV converter box?
By WhoMe2 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 25th Sep 2017, 18:16 -
How to use cable converter box?
By DigBick in forum DVB / IPTVReplies: 10Last Post: 15th Sep 2016, 16:18 -
Digital Converter Box for TV (how to hook up)
By jay333 in forum Newbie / General discussionsReplies: 6Last Post: 10th Nov 2013, 22:02 -
Do you know of any 3D converter box that work with passive glasses?
By Big-Louis-1971 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Oct 2013, 22:00
