Hello.
I would like to synchronize Video/Audio that come from 2 sources.
1) The Video Source is from blu-ray at (23,976 fps)
2) The Audio Source is from a dvd that come from PAL Region 2 (25,000 fps) foreign language (French here)
3) I have done the audio conversion already to 23,976 fps, so the length is almost the same now
4) THIS IS WHERE I NEED HELP. I would love the match the audio & video as good as we can find on Blu-ray/DVD on the market. Which software and ''how to'' do it ? I've read that it's possible to do it in ''auto mode'' to match to ms accurate.
Thanks,
kalemvar
If you just need to adjust the audio skew you can use a player like MPCHC or MPCBE that lets you delay/advance the audio as it's playing. Then set the audio delay (an negative delay is an advance) when you mux .
Be aware that releases in different countries are often different cuts of the movie with shots added or removed. So it may not be as simple as just making the audio the same length as the video and setting an initial delay.
An easy way to combine audio & image into video?
By Aquinax in forum Video ConversionReplies: 10Last Post: 17th Jul 2016, 14:47 -
Synchronize video from 1.video and sound from 2.video using compare videos
By ad48 in forum EditingReplies: 0Last Post: 3rd Apr 2015, 07:18 -
video & audio sync tweat help
By FuzMic in forum AudioReplies: 1Last Post: 27th Aug 2014, 17:09 -
Video & Audio are out of sync - help please.
By chrisj in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2014, 09:47 -
ffmpeg 2.0.2 vs. 2.1 extracting audio&video from mpls, problem
By Selur in forum Video ConversionReplies: 0Last Post: 2nd Nov 2013, 09:22
