Hello,
Those who own a Panasonic NV-HS860 know that after loading the tape it displays this message: Checking tape number. Please wait! And then afterwards: Tape ID could not be detected. I don't know if this is a Feature found only on HS860, but for me it is very annoying because I can't find a way how to disable this function.
It is annoying because I know that there is no ID on my or other's VHS tapes and because of that it is a complete waste of time. So at first I have to wait and so waste some time. And secondly after checking the tape number the tape transport has to rewind the tape slightly back to the start. For some reason (possibly a bad belt) my HS860 has problems to Rewind back when the tape is close to the beginning and so i must use my other VCR to Rewind the tape. Not to blame my HS860 I must tell that it Rewinds properly when the tape is not near the start position. And it Rewinds fine tapes in good condition.
Maybe someone knows how to disable this function? There is a way how to override this feature- you must imediatly push the Play button while the tape is loading. But that does not work for 100%.
Thanks,
Maris
Panasonic NV-HS860, LG LV 880 HiFi 6 Head, Sony SLV-SE 630 HiFi, LG BL-162W, Sony TRV33E miniDV for Capture, Canopus ADVC 55, Panasonic DMR-ES10, Sony Vegas Pro12, WinDV
Break the record safe tab off the cassette and the library system will not run.
Panasonic NV-HS860 and others in that range
By Quasipal in forum RestorationReplies: 11Last Post: 16th Sep 2018, 09:40 -
Checking metadata in .mov file
By jochristiaans81 in forum Newbie / General discussionsReplies: 13Last Post: 7th Jan 2018, 11:24 -
Panasonic AG-1980 won't play a tape... it just ejects it
By syrist in forum RestorationReplies: 25Last Post: 15th Dec 2016, 05:25 -
checking videos
By natty in forum Newbie / General discussionsReplies: 8Last Post: 24th May 2016, 07:04 -
Vintage Panasonic M5 camcorder wont eject tape
By coffee_king in forum CapturingReplies: 1Last Post: 23rd Nov 2015, 21:35
