A friend placed a VCD that I had burned him into an Apex-660 model and he told me that the PBC On message comes up but the VCD does not play.
I do not have that model but it worked fine on my Geneca model.
Any ideas ? Was it the burning or the player ? I did check the compatbility list and it is compatible with VCDs. Oh and I used the 640 TDK from Best Buy
Thanks for the help in advance
Paolo
The DVD player can play VCD BUT .........IT CAN NOT PLAY CDRs....
That is your problem. The DVD players have to be able to read CD-rs. A lot of DVD player do not have this ability so It can not read the VCDs you are making.
You can get a DVD player that reads CDRs for around $100 and above.
www.vcd-trading.com
Check it Out and Start Trading Today! -
The Apex-660 will play CD-R's just fine, but will not play many CD-RW's. Most likely the mpeg file you put on the disk is not fully VCD compliant. The Apex will not play XVCD's unless you remux the mpeg file in Tmpeg with a new VCD system info header. So, run the file through the simple remux, and then burn the file to a CD-R. It should play just fine in the Apex.
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 17:57 -
Weird component problem with LG555 and Apex tv...
By dvd mon in forum DVD & Blu-ray PlayersReplies: 9Last Post: 3rd Jan 2011, 14:40 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 05:35 -
Pioneer 660 HDD Recorder First Impression
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 26th May 2008, 20:20
