I wonder if there is an easy solution to compare two video files (one is original, other is converted output) to check if the frames of the converted one was shifted? The source is interlaced, the output is interlaced, but field order changed.
I use Subtract() in AviSynth:
Open the script in VirtualDub and scrub through it. Differences will be very obvious.Code:v1 = LWlibavVideoSource("video1.mkv") v2 = LWlibavVideoSource("video2.mkv") # use Loop or Trim to align them if they start at different frames Subtract(v1,v2) ColorYUV(cont_y=2000) # make differences more visible -
I also tried to mach interlaced to progressive (deinterlaced). I tried that with exporting 2 frames from each video from Virtualdub as jpeg, and compare them in Vegas placing them above each other on the timeline. I guess this way I have to focus on horizontal comparison, shouldn't I? I can see when I switch from progressive to interlaced variant that the preview is doing a vertical jump, very likely because of the fact that the deinterlaced image is between the two fields regarding height. Horizontally there is no jump occuring when switching, so that should mean the deinterlaced frame is on time, isn't it?
Understanding original frame rate & type for this clip
By Imy in forum Video ConversionReplies: 4Last Post: 16th Apr 2018, 14:26 -
How to Determine Original DVD Frame Rate & Frame Type
By lomaidala in forum Video ConversionReplies: 30Last Post: 3rd Jul 2017, 07:42 -
Some Videos the original aspect Ratio is incorrect and will not convert.
By Kurt a Wells in forum Video ConversionReplies: 19Last Post: 23rd Jun 2017, 20:04 -
Telecine and irregular dupe mix - restore original frame rate ?
By LMotlow in forum RestorationReplies: 16Last Post: 14th Jul 2014, 20:09 -
Fixing white balance shift shift
By yardline in forum EditingReplies: 6Last Post: 11th Mar 2014, 15:51
