My Samsung LN40B650 is cutting off part of my picture. Even when I select the "Screen Fit" option in the TV menu, which is supposed to show the entire picture, a small portion of the picture still gets cut off. I have gone into the service menu and tested out the menu options and I haven't found anything that fixes this issue of the overscan area not being displayed. I can access every part of the service menu except for a section called "advanced". When I try to access "advanced" on my remote, nothing happens. I am using a universal remote and I don't have the original remote that came with the TV so I don't know if I need the original remote to access the "advanced" section. I just want to see if there is an option to this overscan problem in the "advanced section".
Does anyone know the overscan option in the service menu would be called or if it is even possible to fix this problem?
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Samsung call is Just Scan. On my Samsung TV (older model) it's accessed via the blue P-Size button. On some TVs you get the non-overscan mode by switching the input name to PC or Computer, or some such.
Overscan issue with LG 22LH20R
By binario in forum DVB / IPTVReplies: 1Last Post: 17th Jan 2017, 10:36 -
Samsung writer won't reinstall, not supported by Samsung
By blacktooth in forum DVD & Blu-ray WritersReplies: 4Last Post: 11th Jan 2017, 23:47 -
Question about caputring VHS and overscan
By kangarooster in forum CapturingReplies: 22Last Post: 1st Nov 2015, 23:02 -
Is overscan area included in digitizing 720 X 480 video?
By 90sTV in forum Newbie / General discussionsReplies: 13Last Post: 6th Aug 2015, 20:03 -
Hi8 noise at bottom - not overscan - what causes it?
By cym in forum CapturingReplies: 12Last Post: 17th Sep 2014, 06:51
