Using Toast 8 with Mac 10.10.5. I've edited a bunch of .mov videos and saved as .mp4.
The .mp4s add up to a little more than 2 GB. But Toast insists there's not enough room on my 4.6 (I understand the usable capacity actually is 4.3) GB blank DVD-R.
I've successfully done this in the past, with the same software, same equipment. Does it make sense that Toast would say the disc doesn't have enough space?
* Yes, it's saying not enough space on the blank DVD. It's not saying there's not enough memory on my hard drive.
* Yes, I've tried it with other blank DVDs, same result.
* I've tried saving as an image file, to burn on the DVD. But the image file ended up being around 12 GB.
Thanks for any insight.
If you are writing the files to a data disc there will be no problem (but you won't be able to play the files on a regular DVD player). If you're making a movie DVD the files probably have to be rencoded with DVD specs which means MPEG 2. How big the files are depends on the bitrate you use. Since your ISO image is 12 GB and a DVD is 4.3 GB you have to reduce the bitrate to about 1/3 of what you're currently using. MPEG 2 is less efficient than AVC or HEVC and requires higher bitrates to retain quality. So your quality will likely suffer.
The (recent) Toast manual says that it encodes for up to 2.5 hours of video per DVD layer. For more hours of video, you may need to split that over multiple discs.
It is a bit content dependent, as scenes with random movements (fire, water, crowds, handheld camera), or fast action, will require more bitrate than slow scenes (talking heads).
Old guy needs some help moving DVD's to blu-ray for space?
By yearofthespider2k3 in forum Authoring (Blu-ray)Replies: 15Last Post: 31st Dec 2017, 01:04 -
DVD Flick + Imgburn Error - there doesn't appear to be enough space on ...
By mediaguy7 in forum ComputerReplies: 15Last Post: 11th Aug 2016, 14:58 -
space between dvd download on dvd flick
By klo7 in forum Authoring (DVD)Replies: 1Last Post: 2nd Jan 2016, 18:02 -
DVD-R showing no files but no space available
By augustqueen in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2015, 21:40 -
Hauppauge PVR 2 1512 bitrate vs. DVD disk space
By gliebisch in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2015, 09:28
