Hello,
i have a problem with RipBot. Every image I want to copy is aborted with a demuxing error. Can someone explain why?
Enclosed the logs:
demuxlog:
eac3to v3.33
command line: "C:\Users\Stalker\Downloads\RipBot264v1.23.0\Tools \eac3to\eac3to.exe" "F:\" 1) 2: "D:\Temp\RipBot264temp\job1\video.mkv" -seekToIFrames 6: "D:\Temp\RipBot264temp\job1\audio_1_German.eac3.w6 4" -down16 8: "D:\Temp\RipBot264temp\job1\8_subtitles_English_10 80.sup" 9: "D:\Temp\RipBot264temp\job1\9_subtitles_French_108 0.sup" 10: "D:\Temp\RipBot264temp\job1\10_subtitles_German_10 80.sup" 11: "D:\Temp\RipBot264temp\job1\11_subtitles_Arabic_10 80.sup" 12: "D:\Temp\RipBot264temp\job1\12_subtitles_Danish_10 80.sup" 13: "D:\Temp\RipBot264temp\job1\13_subtitles_Dutch_108 0.sup" 14: "D:\Temp\RipBot264temp\job1\14_subtitles_Finnish_1 080.sup" 15: "D:\Temp\RipBot264temp\job1\15_subtitles_Norwegian _1080.sup" 16: "D:\Temp\RipBot264temp\job1\16_subtitles_Swedish_1 080.sup" 17: "D:\Temp\RipBot264temp\job1\17_subtitles_English_1 080.sup" 18: "D:\Temp\RipBot264temp\job1\18_subtitles_French_10 80.sup" 19: "D:\Temp\RipBot264temp\job1\19_subtitles_German_10 80.sup" 20: "D:\Temp\RipBot264temp\job1\20_subtitles_Dutch_108 0.sup" 21: "D:\Temp\RipBot264temp\job1\21_subtitles_French_10 80.sup" 1: "D:\Temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="D:\Temp\RipBot264temp\job1\demuxlog.txt"
M2TS, 1 video track, 5 audio tracks, 14 subtitle tracks, 2:10:30, 24p /1.001
1: Chapters, 18 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz, dialnorm: -4dB
(core: DTS, 5.1 channels, 1509kbps, 48kHz, dialnorm: -4dB)
4: AC3, English, 2.0 channels, 320kbps, 48kHz, dialnorm: -27dB, -15ms
5: E-AC3, French, 7.1 channels, 896kbps, 48kHz, dialnorm: -26dB
(core: AC3, 5.1 channels, 512kbps, 48kHz, dialnorm: -26dB)
6: E-AC3, German, 7.1 channels, 896kbps, 48kHz, dialnorm: -25dB
(core: AC3, 5.1 channels, 512kbps, 48kHz, dialnorm: -25dB)
7: AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB, -15ms
8: Subtitle (PGS), English
9: Subtitle (PGS), French
10: Subtitle (PGS), German
11: Subtitle (PGS), Arabic
12: Subtitle (PGS), Danish
13: Subtitle (PGS), Dutch
14: Subtitle (PGS), Finnish
15: Subtitle (PGS), Norwegian
16: Subtitle (PGS), Swedish
17: Subtitle (PGS), English
18: Subtitle (PGS), French
19: Subtitle (PGS), German
20: Subtitle (PGS), Dutch
21: Subtitle (PGS), French
Creating file "D:\Temp\RipBot264temp\job1\chapters.txt"...
[v02] Extracting video track number 2...
[s09] Extracting subtitle track number 9...
[s19] Extracting subtitle track number 19...
[s14] Extracting subtitle track number 14...
[s18] Extracting subtitle track number 18...
[s16] Extracting subtitle track number 16...
[s08] Extracting subtitle track number 8...
[s15] Extracting subtitle track number 15...
[a06] Extracting audio track number 6...
[a06] Removing AC3 dialog normalization...
[v02] Muxing video to Matroska...
[a06] Extracting E-AC3 core...
[a06] Decoding with libav/ffmpeg...
[s20] Extracting subtitle track number 20...
[a06] The libav decoder reported error -22 while decoding. <ERROR>
[s12] Extracting subtitle track number 12...
[s13] Extracting subtitle track number 13...
[s21] Extracting subtitle track number 21...
[s17] Extracting subtitle track number 17...
[s11] Extracting subtitle track number 11...
[s10] Extracting subtitle track number 10...
Aborted at file position 1048576. <ERROR>
test.log:
ffprobe version N-90936-gdc7a8f7310 Copyright (c) 2007-2018 the FFmpeg developers
built with gcc 7.3.0 (GCC)
configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth
libavutil 56. 18.100 / 56. 18.100
libavcodec 58. 19.100 / 58. 19.100
libavformat 58. 13.100 / 58. 13.100
libavdevice 58. 4.100 / 58. 4.100
libavfilter 7. 21.100 / 7. 21.100
libswscale 5. 2.100 / 5. 2.100
libswresample 3. 2.100 / 3. 2.100
libpostproc 55. 2.100 / 55. 2.100
[avisynth @ 0000000000524440] DirectShowSource: couldn't open file D:\Temp\RipBot264temp\job1\video.mkv:
Das System kann die angegebene Datei nicht finden.
(D:\Temp\RipBot264temp\job1\getinfo.avs, line 2)
D:\Temp\RipBot264temp\job1\getinfo.avs: Unknown error occurred
greeting
Results 1 to 1 of 1
Ripbot 264 demuxing error
By zsolt67 in forum Video ConversionReplies: 7Last Post: 6th Oct 2018, 03:53 -
RipBot Decoding Error
By Predator1 in forum Authoring (Blu-ray)Replies: 4Last Post: 22nd Jul 2018, 17:55 -
Need help with RipBot decoding error
By flxz in forum Video ConversionReplies: 2Last Post: 1st Jan 2018, 16:10 -
RipBot Error - It keeps shutting down
By FiveFingeredStyre in forum Blu-ray RippingReplies: 7Last Post: 29th Sep 2017, 17:44 -
RipBot Error
By Jake802 in forum Video ConversionReplies: 5Last Post: 5th Jun 2014, 07:24
