I have a problem with automatic switching to proper audio track in MPC-HC when internal audio switcher is enabled. In that case by default internal track is chosen instead of external with proper language even if it doesn't match language priorities. If I disable internal audio switcher then two audio tracks are played simultaneously. In case if there are only internal tracks then proper language is chosen without any problem. I couldn't find a solution so please help me.
I've never been able to get the built-in LAV splitter to select languages, but if you have your preferred languages set under Options/Playback, and the first part of the audio track's name is identical to the whole video file name, and the three letter language code is in square brackets, it should work. Under Options/Playback "auto-load audio files" must also be checked.
For "My Video.mkv" the audio name must begin with "My Video", but I don't think it matters from there, aside from the brackets. ie
This Is My Movie.mkv
This Is My Movie 02 [fre] delay 64ms.ac3
There may be other magic combinations, but that's the only one I'm aware of.
PS. The tooltip for the language section offers an example that could be interpreted as including quotes.
It looks something like this,
"fre jap eng"
but they should be entered like this,
fre jap eng
or comma separated codes should also work
fre,jap,engLast edited by hello_hello; 25th Aug 2018 at 01:07.
(SYNCING & AUDIO ISSUES) Having problems with external filters in MPC-BE.
By Cuddlefish in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2017, 19:08 -
m2ts files on BD playing with english audio track with MPC-HC?
By Gurd99 in forum Newbie / General discussionsReplies: 1Last Post: 17th Aug 2015, 04:35 -
How do I (BATCH) set a specific subtitle track, and audio track as default?
By MountainSplash00 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2014, 07:53 -
ffmpeg force default audio track in mp4 container ?
By logicom in forum Video ConversionReplies: 7Last Post: 27th Nov 2014, 10:02 -
VLC lets me change Audio Track, MPC-HC doesn't - It's grayed out!
By elgy in forum Software PlayingReplies: 15Last Post: 28th Feb 2014, 10:32
