I'm a novice at video encoding. Yet, I've found a great x265 downsizing encoding routine for my large television captures.
I can reduce the file size by 40% or more.
But I notice the resulting x265 encode looks noticeably smooth or blurred - with perhaps accentuated edges.
In my current situation, I'm actually satisfied with the result. As I regard it almost like a beautification "touch-up".
But I can imagine potential scenarios where this "smoothing" or "blurring" might not be desirable.
So in those cases, I was wondering if there were any x265 options or commands that could control this aspect of encoding?
Results 1 to 12 of 12
There's an x265 option named "--tune" that can be set to "grain". Please find the details at:
https://x265.readthedocs.io/en/default/presets.html#tuning -
One of the settings that has a large effect on "blurring" for x265 is SAO (it's set to zero in the grain preset) . Many people disable it with --no-sao. But it can be useful for low bitrate, or very clean encoding, or simple cartoons
You usually don't want to use such high --psy-rd and --psy-rdoq settings if not wanting to preserve grain . Much lower than the values used in the --tune grain preset (4 and 10 respectively) -
So I'm encoding high bitrate captures of "reality tv" programming.
One thing I notice is that my x265 compression routine "erases" fine details on skin (like moles & blemishes)...granted, it's mostly in zoomed out shots.
That sort of tells me the "blurring" is a little extreme in my current x265 encoding formula.
You recommended playing with "--no-sao".
And also trying values lower than the grain defaults for "--psy-rd" and "--psy-rdoq"
I'll play around with these values tonight.
If you have any other ideas, let me know.
Tune Grain is the best for avoiding blurring and preserving fine detail --given that you allow it enough bitrate to work with--, it is not just for grain, it works with any kind of detail in your source.
I'm not entirely sold on the idea that a lower CRF can fix the problem...because I originally used "CRF 8" for my x265 conversions.
Even in that, I would notice the "smoothness/blurring" effect. Though it wasn't as pronounced.
And all that effort, for a negligible 1-3 GB reduction - on an 8 GB video.
I settled on "CRF 14", because the "smoothness/blurring" produced an interesting aesthetic effect on the type of material I was converting.
But more importantly, I got massive 40%+ size reductions.
Ideally, I'd like to preserve the reduction-levels around that band...but see if I can "cheat the system" by tweaking or filtering to preserve more details.
Thanks for the clarification. I should probably start with this simple modification, then fine tune it.Last edited by MishaPrada; 25th Aug 2018 at 01:01.
CRF8 using x265 will usually be larger than the original at default settings (assuming the "original" was some typical compressed source) . There should be no blurring at CRF8 . To put things into perspective, At CRF4, that is mathematically lossless for x265 (it was CRF0 for x264) - at that point it will usually be many times larger than the original . If you got a 1-3GB reduction on a 8GB video using CRF8 - something seems very off
So I'm wondering if something else is going on , or maybe some of your commands are not passing through correctly
How are you capturing ? What hardware and recording format ?
Are you preprocessing your captures correctly ? Are they interlaced ,or telecined, or native progressive ?
Are you using x265 directly or through some GUI, or libx265 through ffmpeg ?
Tune grain will definitely steer you towards retaining fine details, skin pores, fine textures, etc... - that sort of thing . But at a given CRF , it will make the filesize much larger. If you don't have a grainy source, and you don't want to preserve film grain, I would definitely lower the "--psy-rd" and "--psy-rdoq" settings from the preset . Those settings in the preset are only meant to be a "starting point" anyways. It also tends to add edge artifacts when you use higher psy values. Grain usually "covers" that up. If you have a grainless,clean source, you will notice the artifacts more. The compression ratio is also lower, because of ip/pb ratios (the idea there was to minimize grain fluctuations between i/b/p frame quality, and again, it's not as useful for a clean source)Last edited by poisondeathray; 25th Aug 2018 at 01:17.
Happy to report, some simple changes to "--psy-rd". "--psy-rdoq", and "--rdoq-level" produced the effect I wanted.
I can confirm, the small mole on Alison Brie's neck is preserved - after x265 conversion.
Source (1080p Television capture, 3 minutes long) = "Bit rate: 43.1 Mb/s, File size: 916 MB"
Past CRF 14 conversion (soft & aesthetically blurry) = "Bit rate: 6827 kb/s, File size: 151 MB"
New CRF 14 conversion (sharper & more textured) = "Bit rate: 10.3 Mb/s, File size: 225 MB"
Thanks for the help guys.
I now have one "softening" routine for sub-par captures.
And one "sharpening" routine for clean captures. -
For the softness routine, it's basically just "--crf 14.00" & desired speed preset.
For the sharpness routine, it's also "--crf 14.00" & desired speed preset...with addition of "--rdoq-level 1", "--psy-rdoq 3.00-6.00", and "--psy-rd 2.0".
To my mind, "--psy-rdoq" is basically the key to the whole thing. I just look at my source & determine how much I can get away with. Then pick something within that 3-6 band.
How i can encode audio of "REMUX" to "BluRay.720p.DTS" wit handbrake?
By VideoHelp4Ever in forum Blu-ray RippingReplies: 1Last Post: 2nd Jul 2015, 12:41 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
[Help] Problems with the "Title Button" in the "VTS ROOT" and "VTS Normal"
By kirous in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2014, 13:31 -
How to convert "Still Image" to "AVC file" (like as Godzilla Blu ray Menu)
By ningnong132 in forum Video ConversionReplies: 2Last Post: 8th Sep 2014, 05:23 -
the "-intra" command in ffmpeg.exe affects encoding "-vcodec copy" mode?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 16:53
