Thread: Roland V 60 HD and RS 232
  1. #1
    Henk
    Aug 2018
    Vlaardingen
    Posts
    1
    Hey,
    We have a Roland V 60 HD mixer and want to use the remote software to connect a RS232 connection on the mixer to a laptop that has no RS232 port, now the question... with a gradient from USB to RS 232 to use all possibilities or give this problems...
    thank you in advance
    Henk
    Member
    Dec 2005
    Posts
    59,226
    Re: Roland V 60 HD and RS 232
    I don't know that particular device but I've used USB/RS232 adapters to communicate with other serial devices. This is transparent to software running on the PC so it should work. The adapters aren't expensive so you might as well try it.
    I noticed the Roland V60HD has an ethernet port for control. Can't you use that?
    I have a USB to RS232 converter and it has worked just fine for a number of old pieces of serial port hardware.
  1. good TBC by roland videomixer
    By 280634157 in forum Capturing and VCR
    Last Post: 26th Apr 2018, 12:59
  2. Roland VC-30HD DV HDV MPEG-2 TS, USB / Firewire Capture Deck
    By dellsam34 in forum Capturing and VCR
    Last Post: 30th Jan 2016, 18:32
  3. How do I Record a Live CCTV Broadcast coming from a Roland Video Mixer?
    By Andrew Prince in forum Newbie / General discussions
    Last Post: 4th Oct 2015, 07:43
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
